  • Denon DHT-S316 2.1 Channel Soundbar System with Wireless Subwoofer
CLEARANCE Denon DHT-S316 2.1 Channel Soundbar System with Wireless Subwoofer
Denon
Part #245-4032
Denon
Part #245-4032
Introducing the Denon DHT-S316 home theater sound bar system, complete with a wireless subwoofer, HDMI/ARC, Bluetooth connectivity, and advanced Dolby Digital and DTS decoding technologies. Experience superior audio quality and immersive surround sound in your home entertainment setup.
  • 2.1-Channel Configuration
  • External Wireless Subwoofer
  • Bluetooth Connectivity
  • HDMI ARC, Optical, 1/8" Inputs
CLEARANCE $299.00
1In Stock
The DHT-S316 boasts a Low-Profile Design, standing at approximately 2" tall. This slim profile allows it to fit seamlessly into most spaces and can be conveniently placed in front of your display without obstructing its bottom edge or IR remote sensor. Additionally, the soundbar offers the flexibility of wall-mounting through the built-in keyholes, enhancing the aesthetic appeal of your setup.
Experience enhanced audio depth with the Wireless Subwoofer of the Denon DHT-S316 soundbar system. Elevate your movies, music, and shows by adding the missing deep bass, all without the constraint of wires. Thanks to its wireless connectivity, you can position the subwoofer anywhere in your theater room, ensuring optimal sound distribution.
Utilize the HDMI ARC Input to simplify your audio connections. Transmit audio from apps embedded in your smart display and other sources using the Audio Return Channel (ARC) input on the soundbar, requiring just a single HDMI cable. This connection not only streamlines your setup but also enables easy control of the soundbar via your compatible display's remote control, thanks to its Consumer Electronics Control (CEC) compatibility.
Enhance your music streaming experience with Bluetooth Connectivity. Pair your compatible smartphone or tablet with the soundbar to effortlessly stream your favorite music via Bluetooth, adding convenience to your entertainment.
The Denon Dialogue Enhancer is a specialized feature designed to improve the clarity of dialogue in movies and TV shows. It increases the intelligibility of spoken words without adjusting the overall volume, ensuring you catch every word and nuance.
Enjoy immersive surround sound simulation with Dolby Digital and DTS Decoding, delivered through Denon Virtual Surround mode. This feature realistically replicates a multi-channel home theater surround sound speaker system, enhancing your viewing experience for Blu-ray, DVD, DVB, and other surround-encoded media. The soundbar utilizes psychoacoustic algorithms to create a lifelike home cinema environment.
Designed for effortless setup, connect the soundbar to your compatible display using the provided HDMI or optical cable. If you're utilizing HDMI via an ARC connection on your display, you can conveniently control the soundbar using your display's remote, streamlining your overall entertainment system setup.
Soundbar
Channel Configuration 2.1-Channel
Midrange Drivers 2 x Cone
High-Frequency Drivers 2 x Tweeter
Subwoofer
Enclosure Type Bass-Reflex
Drivers 1
Subwoofer Inputs/Outputs Wireless
Connectivity
Inputs
1 x HDMI - ARC
1 x Optical TOSLINK - Audio
1 x 1/8" / 3.5 mm - Audio
Outputs None
USB I/O 1 x USB-A (Unspecified Interface)
Wireless Audio Protocols Bluetooth
Wireless Bluetooth 4.2
NFC No
Bluetooth Profiles A2DP 1.3, AVRCP 1.6
Bluetooth Codec Support SBC
Bluetooth Frequency Response 20 Hz to 20 kHz (A2DP)
Wireless Range 32.8' / 10 m
Compatibility
Audio Decoding DTS Digital Surround, Dolby Digital,
Sampling Frequencies 32, 44.1, 48 kHz
HDMI Compliance ARC, CEC
Power
Power Consumption 40 W (Soundbar)
0.3 W (Soundbar, Standby)
1.6 W (Soundbar, Standby)
40 W (Subwoofer)
0.26 W (Subwoofer, Standby)
1.1 W (Subwoofer, Standby)
AC Input Power 120 VAC, 60 Hz
Operating Temperature 41 to 95°F / 5 to 35°C
Physical
Wall Mountable Yes
Dimensions, Soundbar 35.4 x 2.2 x 3.2" / 89.9 x 5.6 x 8.1 cm
Dimensions, Subwoofer 6.7 x 12.3 x 13.4" / 17 x 31.2 x 34 cm
Weight 4 lb / 1.8 kg (Soundbar)
11.5 lb / 5.2 kg (Subwoofer)
BrandDenon
ModelDHT-S316
Part Number245-4032
UPC883795004671
Weight20.1
