  • Shadow Mounts THIN2337 Super Slim TV Wall Mount 23"-37"
CLEARANCE Shadow Mounts THIN2337 Super Slim TV Wall Mount 23"-37"
Shadow Mounts
Part #182-346
Shadow Mounts
Part #182-346
Model: THIN2337
Mounting your TV should be a quick, simple process... and it is with the Shadow Mounts THIN2337 super slim Shadow Mount! In minutes your TV will be mounted less than half an inch off the wall.
  • Works great for point-of-purchase displays and portrait display applications
  • Holds TVs less than 7/16" off the wall
  • Installs in minutes
  • Durable cold steel construction
  • Great for picture perfect installations
  • UL® listed
CLEARANCE $10.89
MSRP: $21.99
Save $11.10 (50%)
83In Stock
HDTV mounting systems should all be this easy to install! In a matter of minutes, you can be enjoying your wall mounted TV. The super slim design holds your TV as close to the wall as possible for a custom look. Built into each TV bracket is a spring loaded clip that locks your TV in place onto the mounting rail. Removing the TV for adjustment or cable connection is quick and easy using the included release draw cord.
Specifications: • Mounting rail dimensions: 20.7" W x 2" H • TV mounting bracket dimensions: 1.75" W x 13.5" H • Distance from wall to back of TV: 0.4" • VESA sizes supported: 50 mm W x 50 mm H to 400 mm W x 300 mm H • Maximum weight capacity: 90 lbs. • UL® listed.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelTHIN2337
Part Number182-346
UPC844632094972
Weight2.85
Mount StyleWall Mount
Mount TypeFixed
TV Capacity33" to 48"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
