  • Shadow Mounts NBS-T Commercial Tilting TV Wall Mount 32"-80"
Shadow Mounts
Part #182-407
Shadow Mounts
Part #182-407
Model: NBS-T
The Shadow Mounts NBS-T is an excellent solution for mounting a 32"-80" television in a residential or commercial environment that requires tilting.
  • Safely secures a TV weighing up to 88 lbs. to a wall
  • Allows for tilting of ±12 degrees
  • Easily mount TVs with VESA patterns up to 600x400
  • Simple mounting makes installation a breeze
  • Sturdy steel construction allows for worry-free use for years to come
Your Price: $15.19
MSRP: $25.99
Save $10.80 (42%)
Shadow Mounts' tilting TV mount sits 2.2" from the wall surface. The high-quality steel construction and included mounting hardware make the installation a breeze. The tilting feature allows you to adjust the angle of the TV ±12 degrees for optimal viewing.
Specifications: • Supports 32"-80" flat-panel TVs • Weight capacity: Up to 88 lbs. • Supports VESA patterns up to 600x400 • Tilt: ±12 degrees • Distance from wall: 2.2" • Dimensions: 16-3/4" H x 25-1/4" W x 2-1/4" D.
BrandShadow Mounts
ModelNBS-T
Part Number182-407
UPC848791007675
Weight3.6
Mount StyleWall Mount
Mount TypeTilting
TV Capacity75" and larger
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
