  • Shadow Mounts HM3260 Hanger Style TV Wall Mount 32"-80"
Shadow Mounts
Part #182-344
Shadow Mounts
Part #182-344
Model: HM3260
With Shadow Mounts' hanger style Shadow Mounts, your flat panel LCD or plasma TV will be up in minutes. Just two screws in the wall and two in your TV! The installed display hangs like a framed picture and requires nearly zero clearance.
  • Mount your TV less than 1/2" from the wall!
  • No reaching around TV trying to start screws into mounting points
  • Solid steel construction, supports up to 100 lbs., doesn't droop or sag
  • Quick installation; instructions and hardware included
  • Universal mounting fits most screens 32" to 80"
  • Works great for portrait-style presentations and point-of-purchase displays
Your Price: $11.49
MSRP: $14.99
Save $3.50 (23%)
Quantity:Qty: 1-3 $11.49/ea
Quantity:Qty: 4+$10.34/ea
Four screws are all it takes to attach your HDTV to the wall if you use hanger style Shadow Mounts. These simple, strong, easily installed hangers hold 100 lb. TVs with ease, and need less than 1/2" clearance from the wall.
Using the included hardware and bubble level, mount the rail to your wall, then install two hanger clips on the back of the TV and set the clips into the rail. Quick cable connection is facilitated by the integrated kick stands that fasten to the lower VESA mounting points on your TV. Simply flip out the kick stands, and your TV is placed at a slight upward angle while you work. It really doesn't get any easier than this!
Specifications: • Mounting rail dimensions: 25.4" W x 2.3" H • Distance from wall to back of TV: 0.4" • VESA sizes supported: Up to 600 mm W x 400 mm H • Maximum weight capacity: 100 lbs.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelHM3260
Part Number182-344
UPC844632094965
Weight2.2
Mount StyleWall Mount
Mount TypeFixed
TV Capacity75" and larger
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
