  • Dayton Audio SUB-650 6-1/2" 60 Watt Powered Subwoofer
CLEARANCE Dayton Audio SUB-650 6-1/2" 60 Watt Powered Subwoofer
Dayton Audio
Part #300-625
Dayton Audio
Part #300-625
Model: SUB-650
The Dayton Audio SUB-650 powered subwoofer is a great addition when you need a "little" more bass. The 6-1/2" long-throw subwoofer adds just the right amount of bass to a 2.1 multimedia system, soundbar, or a bedroom sound system. Enjoy all the punch and great features of the larger Dayton Audio powered subwoofers, in an ultra-compact version.
  • Downward-firing flared port design for clean, powerful bass
  • Selectable "Auto-on" mode
  • Heavy duty long-throw 6-1/2" woofer
  • Perfect for small home theaters or listening rooms
  • Unobtrusive textured black vinyl finish
The Dayton Audio SUB-650 6-1/2" powered subwoofer system is the perfect addition to any stereo or multimedia system. This powered sub features a bottom-firing, flared port, bass reflex design for reduced port noise and increased bass response. It also utilizes a long-throw 6-1/2" woofer and up to 60 watts of authoritative power.
The amplifier features high and low level inputs and high level outputs, a phase switch, independent volume control, an auto on/off switch (activated by an input signal) and a variable 12 dB electronic low pass filter. This compact sub is finished in an unobtrusive black vinyl that will complement any decor.
Specifications: • Power output: 60 watts RMS • Frequency response: 42-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions (rubber feet included): 11-1/2" H x 10-3/4" W x 12-7/8" D.
New! Add the 300-580 Dayton Audio Sub-Link XR wireless subwoofer kit to any Dayton Audio powered subwoofer, for limitless placement possibilities and great bass without wires! Click here to go wireless.
ModelSUB-650
Part Number300-625
UPC848791001833
Weight21.25
Woofer Diameter6.5"
    MONSTER DEAL
    OF THE WEEK
    $98.98 EACH
    SAVE 40%
    Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
