  • Dayton Audio MH450 Waterproof 4-Channel Marine / RV Stereo Receiver with Bluetooth and Video Input 50W
CLEARANCE Dayton Audio MH450 Waterproof 4-Channel Marine / RV Stereo Receiver with Bluetooth and Video Input 50W
Dayton Audio
Part #310-290
Dayton Audio
Part #310-290
Model: MH450
Waterproof, powerful, and full of features, this Dayton Audio marine receiver is a great way to add audio and video to your boat, ATV, or side-by-side. Great for beginners and experts alike, this isn't just a receiver; it is a full featured media center!
  • Bluetooth 5.0 allows you to play your favorite music effortlessly
  • Unheard of 5 YEAR Warranty
  • 3 sets of preamp outputs to connect your favorite amplifiers
  • Waterproof design allows you to use the marine receiver virtually anywhere
  • Triggered video input for connecting a backup camera
  • Great sounding boat and RV audio system
  • Awesome audio at a fraction of the name brands
CLEARANCE $99.98
MSRP: $199.99
Save $100.01 (50%)
58In Stock
Dayton Audio's Marine Amplifier is a 50W waterproof 4-channel head unit that is great for use in boats as well as ATVs, side-by-sides, and other outdoor applications. If your project uses a 12-volt power source, the MH450 is the perfect fit.
Plenty of Output
The MH450 boasts an impressive number of analog and digital connections. In addition to the four 50 watts max speaker outputs, there are three sets of high output RCA preamp outputs (front, rear, subwoofer). The higher output levels provide increased sound quality with a lower signal-to-noise ratio. Having a dedicated subwoofer output makes it easy to extend the low end of your system without additional adapters or converters.
Extreme Capabilities
From a listening to a baseball game on the radio to watching music videos; whatever you want to listen to, the MH450 has the connection to make it happen. The built-in radio has AM (530-1710 kHz) and FM (87.5-107.9 MHz) can store 18 FM and 12 AM presets for easy recall of your favorite stations. RCA audio and video inputs allow for any analog device to be connected and the USB connection can read iOS and android devices and can play video on the built in 3" screen or output it to external monitors. The MH450 also uses Bluetooth 5.0 to stream high quality audio from your mobile device. No wires means that your valuable electronics can stay safe and dry while you listen to your favorite tunes on the water.
Prepared for the Elements
This marine receiver is ready to perform in the great wet outdoors. The IP66 water resistance rating means that you won't have to worry about damage to your receiver when you are out-and-about in the great outdoors.
Easy and Safe to Use
No matter what type of vehicle you are operating we know that your attention is in high demand. That is why this marine receiver's large backlit buttons are easy to read, day or night. The MH450 features a connection for a rear backup camera that will automatically show what is behind you whenever the vehicle is in reverse with the backup camera trigger input, helping to ensure you and your party stay safe.
• Power output: 4 x 13W RMS (45W max) @ 4 ohm
• Frequency response: 20 Hz to 20 kHz
• Total Harmonic Distortion: 0.5%
• Signal-to-noise ratio: 86 dB
• Channel crosstalk: -67 dB
• RCA output: 4V
• AM frequency range: 530 - 1710 kHz
• FM frequency range: 87.5 -107.9 MHz
• Supported audio formats: MP3, OGG, FLAC, APE, AAC, AC3, ATRA, DTS
• Supported video formats: MKV, AVI, MOV/MP4, TS, ASF, FLV, PMP, RMVB, MPG/VOB, WMV
• Supported picture formats: JPEG, BMP, GIF, PNG
• Screen size: 3"
• Screen resolution: 640 x 360
• Mounting depth: 5"
• Mounting hole cutout size: 3"
• Front panel dimensions: 4.5" W x 4.13" H
ModelMH450
Part Number310-290
UPC848791007750
Weight2.75
Aux InputAudio/Video
Bluetooth CapableBuilt-in Receiver
Preamp Outputs3
Receiver Type4 Channel Stereo
USB InputRear
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
