  • Shadow Mounts LCD60-TM Tilting TV Wall Mount 37"-90"
Shadow Mounts
Part #182-322
Shadow Mounts
Part #182-322
Model: LCD60-TM
The Shadow Mounts LCD60-TM tilting TV wall mount is designed to work with 37"-90" LCD and plasma TV displays using up to a VESA 600 mm x 400 mm bolt pattern. These TV mounts focus the attention on the television instead of the bulky mount.
  • Easy adjustable ±15° tilt places screen in the optimum viewing position
  • Solid steel construction—supports up to 175 lbs.
  • Quick installation, instructions and hardware included to get your TV mounted quickly
  • Universal mounting fits most screens
  • Patented Rail Clip™ for quick attachment of hanger feet to lower rail
  • Great replacement for the Shadow Mounts LCD3260-TM LCD/Plasma Tilt Mount 37"-90"
  • UL listed
Your Price: $44.98
MSRP: $51.99
Save $7.01 (13%)
Quantity:Qty: 1-3 $44.98/ea
Quantity:Qty: 4+$40.98/ea
Shadow Mounts place the focus on your flat panel television—not the television mount. By using an inconspicuous flat black finish, the TV mount virtually disappears behind the television display.
The LCD60-TM heavy-duty, solid-steel construction provides you with peace of mind, knowing your HDTV investment is held securely in place for years to come. The patented Rail Clip™ is an exclusive feature that securely fastens the TV mount to the lower wall mount rail, eliminating the need for clumsy set screws and other awkward attachment devices.
The Shadow Mounts LCD60-TM is compatible with 37"-90" LCD and Plasma TV displays that use up to a VESA 600 mm x 400 mm bolt pattern. Note: Consult your TV's owner's manual for VESA sizing information.
Note: Do not to exceed the weight limit of 175 lbs.
Specifications: • Mounting plate width: 32.36" (822 mm) • Mounting plate height: 9.25" (235 mm) • Mounting arm width: 1.375" (35 mm) • Mounting arm height: 20.87" (530 mm) • Tilt adjustment: ±15° • Minimum mount to wall distance: 3.1" (80 mm) • Mounting width supported: 50-770 mm • Mounting height supported: 50-480 mm • Supported VESA sizes: 75, 100, 200 x 100, 200, 400 x 200, 400 x 400, 600 x 400 • Maximum weight capacity: 175 lbs. (80 kg) • UL® listed.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelLCD60-TM
Part Number182-322
UPC844632082481
Weight12.68
Mount StyleWall Mount
Mount TypeTilting
TV Capacity75" and larger
