  • Dayton Audio IB385-8 15" Infinite Baffle Subwoofer
CLEARANCE Dayton Audio IB385-8 15" Infinite Baffle Subwoofer
Dayton Audio
Part #295-455
Dayton Audio
Part #295-455
Model: IB385-8
Build the ultimate home theater subwoofer by doing an infinite baffle installation! The Dayton Audio IB series subwoofers are designed to produce extremely low, clean, uncolored bass without "boxed in" sound.
  • Long excursion design
  • Heavy gauge stamped steel frame
  • Extremely rigid Kevlar-impregnated paper cone
  • Heavy duty treated foam surround
  • Single 8 ohm voice coil on Kapton former
  • Bumped back plate and vented pole piece for reduced power compression
The Dayton Audio IB series subwoofers are designed to produce extremely low, clean, uncolored bass in infinite baffle situations. Ideally, the subwoofers are situated between the listening room and an attic, basement, or garage using the floor, ceiling, or walls to separate the front and rear sound waves.
Benefits of the infinite baffle approach include extreme low-frequency output, very clean and distortion-free sound, lack of large enclosures within the room, and amazingly loud bass with modest power amplifiers. Combining high sensitivity, good mechanical damping, and excellent excursion capabilities, the IB series subwoofers are the only drivers on the market designed specifically for infinite baffle situations. Made in the U.S.A. 5 year Limited Warranty.
ModelIB385-8
Part Number295-455
UPC844632000102
Weight20
Nominal Diameter15"
Power Handling (RMS)350 Watts
Power Handling (MAX)700 Watts
Frequency Response20 to 500Hz
Sensitivity88.2dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)21.5Hz
DC Resistance (Re)5.2Ω
Voice Coil Inductance (Le)3.08mH
Mechanical Q (Qms)8.92
Electromagnetic Q (Qes)0.63
Total Q (Qts)0.59
Compliance Equivalent Volume (Vas)8.79ft³
Mechanical Compliance of Suspension (Cms)0.26mm/N
BL Product (BL)15.46T·m
Maximum Linear Excursion (Xmax)14.3mm
Surface Area of Cone (Sd)819.4cm²
Cone MaterialPaper / Kevlar
Surround MaterialFoam
Overall Outside Diameter15.16"
Baffle Cutout Diameter13.77"
Depth6.34"
Sealed Volume8.61ft³
Sealed F330Hz
Vented Volume19.39ft³
Vented F315Hz
