  • Dayton Audio HTA100BT Hybrid Stereo Tube Amplifier with Bluetooth USB Aux Phono In Sub Out 100W
CLEARANCE Dayton Audio HTA100BT Hybrid Stereo Tube Amplifier with Bluetooth USB Aux Phono In Sub Out 100W
Dayton Audio
Part #300-3842
Dayton Audio
Part #300-3842
  • Authentic vacuum tube warmth and character with class A/B amplifier efficiency produces an articulate and natural sonic experience
  • Powerful 50 watts per channel of audiophile fidelity that is sure to please even the most discerning ear
  • Convenient input connections including USB, optical, coaxial, phono, stereo RCA, and Bluetooth V5
  • Mono RCA subwoofer output gives you the ability to enjoy a 2.1 system when connected to an active sub
  • Brushed aluminum housing with vintage front panel VU meters lends a clean, modern look with a nod to classic aesthetics
  • Short circuit protection circuitry to prevent amp failure
  • Built-in phono preamplifier to easily connect record players
Modern Design Meets Vintage Sound
The Dayton Audio HTA100BT hybrid tube amplifier gives modern amp design a vintage makeover. Featuring the best of modern amp technology and functionality, the HTA100BT provides all of the convenience you to expect from an amp with the added benefit of classic vacuum tube sonic performance.
No Compromises
Debates may rage between whether solid-state or tube amplifiers produce a better listening experience; however, Dayton Audio solves the debate. By harnessing the best qualities of both, Dayton Audio's HTA100BT hybrid tube amplifier utilizes the efficient design of class A/B amp topology while employing vacuum tubes in the preamp circuit. The tubes' subtle character and warmth create a delightful homage to the classic valve amplifiers of the past.
Modern Connectivity with Vintage Flair
Flexibility & Power
With an output power rating of 50 watts per channel at 4 ohms, the HTA100BT packs a serious punch perfect for almost any home audio listening system. The added convenience of Bluetooth V5 ensures that your wireless streaming has the best possible quality and functionality. Front panel controls allow you to skip songs, play/pause, and change the input source.
Connected Versatility
A rear-mounted RCA input allows more permanent connections to larger input sources. Complete with a dedicated phono input, the HTA100BT perfectly pairs with your turntable. The HTA100BT also has a rear-mounted USB drive input that will read the most common audio formats, including MP3, WMA, WAV, and APE. The USB connector is only for media playback from a hard drive or flash drive. Note: USB input does not allow for streaming directly from a computer via USB.
Homage to the Classics
Classic front panel VU meters on the HTA100BT perfectly compliment the modern, sleek, brushed aluminum housing. Exposed tubes only add to the modernized vintage aesthetic of the HTA100BT. A large volume knob, complete with bass and treble controls, on the front panel gives you access to the control you need to dial in your perfect sound.
Sight & Sound
The classic beauty of the HTA100BT makes the amp a perfect centerpiece in your room, while the functionality, power, and superb audio quality make the amp perfect to drive any stereo setup. With the HTA100BT, you receive the best of both worlds in amp design and function, as well as vintage attractiveness. See and hear the difference the HTA100BT gives your audio system.
Control At Your Finger Tips
The HTA100BT gives you complete control from the front panel of the amp. Easily select input source, playback, and tone. In addition, VU meters give the amp a classic feel. Complete with an oversized volume knob, not only is the control at your fingertips, but the amp looks great.
1. Power
2. Source Select
3. VU Meter for Left Channel
4. VU Meter for Right Channel
5. Input Select
6. Play/Pause Control
7. Previous Track
8. Next Track
9. Bass Control
10. Treble Control
11. Volume Control
All The Connections
The HTA100BT provides a vast array of input options with virtually any input device. Stream from USB, Bluetooth, or connect via digital inputs, or an RCA Aux input. The HTA100BT also features a built-in phono preamp to enjoy your vinyl collection. Completed with a subwoofer output, the HTA100BT is perfect for a 2.1 system.
12. Subwoofer Output
13. USB Port
14. Optical Input
15. Coaxial Input
16. AUX1 Input
17. Phono Input
18. Speaker Outputs
19. Cooling Fan
20. Power Input
All Backed By A 5-Year Warranty
What Our Customers Love About The HTA100BT
Don't trust us...trust our customers. Here is what they have to say about the HTA100BT.
Awesome Amp and BT
"Love this thing. Sounds very good and has plenty of power for my 2 Monitor Audio Gold 8 ohm bookshelf speakers." - Ryan E.
Best of the micro amps and the best amp I've used yet.
"I have ordered 3 different amps from Amazon (different make & models) and have decided this is the best...by far. I've had the mono price, Rockville and INFI. The later should have been the keeper but it they went bad on two different units. The Mono and Rockville simply don't have half the power of the Dayton Audio although I'm sure the guts are pretty much the same.
This unit is well built, good looking, the VU meters work off what appears to be pre amp signal (not output like many) and the fan cannot be heard when it needs to kick on at higher volumes. It seems to know when you are 50% or less and shuts down...quickly.
Nice glow from the tubes (fake LED at bottom) and of course as the annoying bright blue tooth selected LED that NOBODY seems to get right...nobody. Best price/value out there with multiple inputs, photo pre amp and moderately good tone controls.
I have not tested SW output and will assume it's on the pre amp volume. I believe I read it's mono output too." -
Shawn F.
  • Power output: 50 WPC RMS @ 4 ohms
  • THD: 0.5% @ 50 WPC
  • Minimum speaker impedance: 4 ohms
  • Channel separation: 50 dB
  • SNR: >80 dB
  • Frequency response: 20-20,000 Hz
  • Sub output: Preout for active subwoofer (HTA100BT is a full range amp with no internal crossover)
  • Preamplifier tube:6U1 x 2, 6F2 x 2
  • Transistors: Toshiba A1941 x 2, Toshiba C5198 x 2
  • Bluetooth: Version 5
  • Supports Bluetooth codecs: SBC and AAC
  • Media playback file support: FLAC, WAV, APE, WMA, MP3
  • Digital audio DAC SNR: 96 dB
  • Digital audio DAC sample rate: Up to 16-bit/48kHz
  • Input impedance: 47 kohms (minimum)
  • Input sensitivity: 350 mV
  • Power: 110/220 VAC, 50/60 Hz Standard IEC Connection
  • Fuse Rating (120v): 5x20mm 5AL
  • Dimensions: 6.6" x 11.5" x 10.6"
Complete HTA Hybrid Tube Amp Collection
Utilizing the efficiency of solid-state class A/B amplifier topology and a vacuum preamp section, the HTA series of amplifiers authentically reproduces the warmth and character of vintage tube amps with the added flexibility and functionality you expect from a modern amp.
Shop the HTA Collection
SPECHTA20BTHTA100BTHTA50BT
Power Output:12WPC RMS @ 4 Ohms50WPC RMS @ 4 Ohms25WPC RMS @ 4 Ohms
Frequency Response:20-20,000 Hz20-20,000 Hz20-20,000 Hz
Amp Topology:Hybrid Tube / Class A/BHybrid Tube / Class A/BHybrid Tube / Class A/B
Inputs:Bluetooth 4.2, 2 x Stereo RCA , USBUSB, Optical, Coaxial, Phono
Bluetooth 5.0, Stereo RCA
Optical, Coaxial, Bluetooth 5.0,
2 x Stereo RCA, USB
Outputs:Speaker, Subwoofer, HeadphoneSpeaker, SubwooferSpeaker, Subwoofer, Headphone
 SHOP NOWSHOP NOWSHOP NOW
ModelHTA100BT
Part Number300-3842
UPC848791007446
Weight13.85
Weight Range10 to 19 lbs.
Special FeaturesBluetooth-USB Connectivity
