Shadow Mounts HM2337 Hanger Style TV Wall Mount 23" - 37"Four screws are all it takes to attach your HDTV to the wall if you use hanger style Shadow Mounts. These simple, strong, easily installed hangers hold 100 lb. TVs with ease, and need less than 1/2" clearance from the wall.
Using the included hardware and bubble level, mount the rail to your wall, then install two hanger clips on the back of the TV and set the clips into the rail. Quick cable connection is facilitated by the integrated kick stands that fasten to the lower VESA mounting points on your TV. Simply flip out the kick stands, and your TV is placed at a slight upward angle while you work. It really doesn't get any easier than this!
Specifications: • Mounting rail dimensions: 9.6" W x 2.3" H • Distance from wall to back of TV: 0.4" • VESA sizes supported: Up to 200 mm W x 200 mm H • Maximum weight capacity: 100 lbs.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
