  • Dayton Audio DML25-4 2" Distributed Mode Loudspeaker Transducer 20W 4 Ohm
Dayton Audio
Part #295-236
Dayton Audio
Part #295-236
Model: DML25-4
Dayton Audio's DML25-4 2" full-range DML speaker combines the compactness of an exciter with the pistonic air modulation of a standard speaker, making it perfect for use in sound bars and compact speakers where smooth off-axis response is needed.
  • Unique, square-shaped form for tight driver-to-driver placement
  • Extended frequency response up to 15,000 Hz due to low a inductance motor
  • Wide off-axis dispersion for placement flexibility
  • Perfect for modern audio applications such as speaker bars and line arrays
Your Price: $9.49
MSRP: $20.99
Save $11.50 (55%)
Quantity:Qty: 1-3 $9.49/ea
Quantity:Qty: 4+$9.36/ea
Estimated back in stock 5/9/2025
Alert Me When Available
The DML25-4 2" full-range transducer, from Dayton Audio, produces an amazing amount of quality sound on and off-axis while maintaining a small form factor. Designed to behave like a conventional pistonic driver at lower frequencies and a DML (distributed mode loudspeaker) and higher frequencies, this driver's unique shape lends itself to modern audio applications, such as a speaker bars, docking stations, and satellite speakers, where sound is to be heard without the source being seen.
Great off-axis directivity enables flexible placement options, while the wide frequency response (that extends from 150 Hz up to 15,000 Hz) delivers cost savings to engineers... no crossover components or frequency-specific drivers are required. The Dayton Audio DML25-4 is a natural selection for designing and building anything from thin column line array speakers to ultra-compact smart speakers.
Dayton Audio outperforms the competition!
ModelDML25-4
Part Number295-236
UPC848791000959
Weight0.25
Nominal Diameter2"
Power Handling (RMS)20 Watts
Power Handling (MAX)40 Watts
Frequency Response150 to 15,000Hz
Sensitivity82.1dB 2.83V/1m
Voice Coil Diameter0.98"
Resonant Frequency (Fs)212Hz
DC Resistance (Re)4.3Ω
Voice Coil Inductance (Le)0.09mH
Mechanical Q (Qms)3.83
Electromagnetic Q (Qes)1.5
Total Q (Qts)1.1
Compliance Equivalent Volume (Vas)0.0008ft³
Mechanical Compliance of Suspension (Cms)0.15mm/N
BL Product (BL)3.86T·m
Maximum Linear Excursion (Xmax)1.5mm
Surface Area of Cone (Sd)16cm²
Cone MaterialPaper
Magnet MaterialNeodymium
Overall Outside Diameter2.63" x 2.63"
Baffle Cutout Diameter2.34" x 2.34"
Depth1.04"
Sealed Volume0.000111ft³
Sealed F3216.4Hz
Vented Volume0.000688ft³
Vented F3136.3Hz
