  • Dayton Audio Framed High Efficiency Audio Exciter 25mm 24W 4 Ohm DAEX25FHE-4
Dayton Audio
Part #295-224
Dayton Audio
Part #295-224
Model: DAEX25FHE-4
Turn almost any surface into a speaker with the Dayton Audio DAEX25FHE-4 framed high efficiency exciter. Thanks to the high mass and powerful neodymium motor, this 24 watt exciter can drive heavier surfaces such as drywall and plywood. In addition, when installed on a light weight material, the DAEX25FHE-4 can deliver incredibly high efficiency and surprisingly wide bandwidth response. With its impressive capabilities, it opens possibilities for unique and innovative audio solutions.
  • Small size; just under 2" diameter, about 7/8" high
  • Pre-applied 3M™ VHB™ adhesive for quick, durable installation
  • Rare-earth neodymium motor and a proprietary voice coil
  • 4-ohm impedance for use with small, Class D amplifiers
  • 24 watt RMS power handling for high output
Your Price: $12.98
MSRP: $16.99
Save $4.01 (24%)
Quantity:Qty: 1-3 $12.98/ea
Quantity:Qty: 4+$12.33/ea
Order in the next 0 hr 5 min to ship today. Details
909In Stock
Dayton Audio's 25 mm DAEX25FHE-4 coin type exciter features the same ability to turn nearly any surface into a speaker, as other exciters and tactile transducers, only in a more compact package for working with smaller surfaces. This exciter's small size enables audio reproduction in places never imagined: toys, monitors, cabinet doors... even windows!
A neodymium magnet is employed to create maximum magnetic flux around the proprietary voice coil for increased sensitivity when compared to similar sized exciters. In turn, this reduces power requirements and makes it possible to use very small audio amplifiers, without sacrificing total output. The 1" voice coil, and cooling vents, allows for more input power for higher output applications while maintaining a slim-line form factor.
To ensure maximum acoustic energy transfer between the transducer and the surface to which it is attached, 3M VHB (Very High Bond) adhesive is pre-applied... just peel and stick! For permanent inverted mounting (or when mounting on moving surfaces), four screw tabs are also provided to support the weight of the exciter. Two PCB solder points keep installation and wiring as compact as possible.
Note: An exciter's frequency response and sensitivity are completely dependent on the exciter's designated surface. Thinner, smaller materials will tend to be louder and create a mid/tweeter response. Thicker, larger materials (with multiple exciters) will be slightly quieter but result in a more full-range sound.
Specifications: • Power handling: 24 watts RMS • VCdia: 25 mm • Nominal impedance: 4 ohms • Re: 4.3 ohms • Le: 0.10 mH • Fs: 224 Hz • Dimensions: 1.99" (50.5 mm) dia. x 0.81" (20.5 mm) H • Adhesive dimensions: 1.09" (27.6 mm) outside diameter, 0.86" (21.8 mm) inside diameter • Weight: 110.9 grams.
To learn more about Dayton Audio Exciters, and for help on which Exciter is right for you, check out Dayton Audio's Understanding and Using Dayton Audio Exciters Buyer's Guide.
ModelDAEX25FHE-4
Part Number295-224
UPC848791000980
Weight0.25
ApplicationFull-Range Exciter
Power Handling (RMS)24 Watts
