DataComm 60-0021-S Single Gang Low Voltage Mounting Bracket
DataComm Electronics
Part #261-505
Part #261-505
Model: 60-0021-S
DataComm's low voltage mounting brackets are designed to retrofit existing construction to mount cable plates flush against the wall. The non-conductive plastic material is perfect for TV, computer, audio, and communications wiring in applications where a low voltage pass through is necessary.
- Non-conductive material
- Adjustable fit for 1/4" to 1" thick drywall
- Quick and easy installation process
- Mounting tabs to fasten the bracket
- Single gang size
