  • DataComm 45-0008-WH Easy Mount Recessed Low Voltage Cable Plate White
1 Question, 3 Answers or
DataComm Electronics
Part #261-518
Model: 45-0008-WH
Use DataComm's Easy Mount Recessed Low Voltage Cable Plate to install low voltage cables behind your flat panel TV, your amplifier or other audio and video devices.
  • Mounting wings are molded into the media plate and fasten tightly against the back of the drywall
  • Mounting wings are designed for use in walls up to 1" in thickness
  • Available colors: White, Lite Almond, Black and Ivory
Your Price: $5.79
MSRP: $9.99
Save $4.20 (42%)
Order in the next 5 hr 40 min to ship today. Details
Use the Easy Mount Recessed Low Voltage Cable Plate to install low voltage cables behind your flat panel TV, your amplifier or other audio and video devices.  The wall plate can be installed upright or upside down. This plate's innovative "mounting wings" eliminate the need for a low voltage mounting bracket. The mounting wings are molded into the Easy Mount wall plate and fasten tightly against the back of the drywall.  The standard Easy Mount Cable Plate has the capacity of a double gang plate-in a single gang profile. The new, thinner profile of the Easy Mount Cable Plate is designed to fit behind the industry's thinnest mounts and flat panel TVs.
BrandDataComm Electronics
Model45-0008-WH
Part Number261-518
UPC660559008089
Weight0.238
FinishWhite
SizeSingle Gang
