The DS18 CANDY-X4B CANDY 4-Channel compact Full-Range Class D 1600W amplifier is the perfect amplifier for people who want a very small footprint and all the benefits that come from larger amplifiers by putting out lots of power in a small package.
The CANDY-X4B can be set up to power either full range speakers, subwoofers, or tweeters with it's built in crossovers and adjustable crossover points. Two independent crossovers allow for the ability to power different sets of speakers between the amplifier's four outputs. Additionally, bass frequencies can be adjusted up to +12dB
With 120 watts RMS (400 watts max) of power per channel at 2 ohms, 80 watts RMS of power per channel at 4 ohms, the CANDY-X4B can also operate in a dual mono mode for a total output of 240 watts RMS (1600 watts max) at 4 ohms bridged.
• Power output: 4 x 80W RMS (@ 4 ohms), 4 x 120W RMS(@ 2 ohms), 2 x 240W RMS (4 ohms bridged mono)
• Frequency Response: 20 Hz - 20 kHz
• Total harmonic distortion: 0.01%
• Signal-to-noise ratio: 100dB
• Dimensions: 234 mm x 127 mm x 47.5 mm (9.21" x 5" x 1.87")
