Twist Lock DC Coaxial Plug & Barrel Power Jack Connector Set 2.5 x 5.5mm
- Jack's long 1/3" shaft thread mounts in up to 1/4" thick panels
- Jack's internal switch cuts off internal power sources if plug is inserted to prevent charging non-rechargeable batteries
- Twist lock action prevents unintended power interruptions
- Standard DC coax 2.5 x 5.5 mm size for higher current projects
Out of Stock
We'll send you an email when Twist Lock DC Coaxial Plug & Barrel Power Jack Connector Set 2.5 x 5.5mm is back in stock or available for preorder.
