Programmable DC-DC Buck Boost Converter 4A 5V to 30V In and 0.5V to 30V Out
- LCD display switches between voltage output and input, output current, output power, output capacity, time of use and board temperature to keep you informed
- Increase or decrease voltage from 5 ~ 30 VDC in to 0.5 ~ 30 VDC out to meet project requirements
- Outputs up to 50W for power hungry small audio projects
- Make your own 3A 30 VDC portable variable power supply with an optional battery board and 5 to 24 VDC AC power adapter
- Plastic body frame snaps it in to a 2.92" x 1.55" (74 x 39 mm) hole for secure mounting
- LEDs for power on and over constant current indicator
- Over/under voltage and current protection plus temperature, time, and capacity protection
We'll send you an email when Programmable DC-DC Buck Boost Converter 4A 5V to 30V In and 0.5V to 30V Out is back in stock or available for preorder.
