Crown XLi 3500 Power Amplifier 2 x 1350W at 4 OhmsCrown's XLi Series of power amps ushers in a new era of affordability without compromising performance. Mobile DJs, bands, and entertainers will appreciate the XLi Series' rugged durability as much as houses of worship, discos, and other venues appreciate the pristine sound quality.
The XLi 2500 puts up to 3,700 watts of Crown Guaranteed Minimum Power at your disposal, with enough input/output options to ensure effortless integration and use in virtually any setup. Does your band need to rock the casbah with full range PA speakers? No problem. Or perhaps you're a home theater enthusiast with a need to feed some monster subwoofers for the most bone-jarring explosions in town? Gotcha covered.
Features common to all XLi amps include RCA and XLR inputs, user selectable input sensitivity of 0.755V or 1.4V, speakON and binding post outputs, stereo/parallel/bridge-mono modes, power/fault/signal presence/clip indicators, forced-air cooling; and protection against shorts, no-load, on/off thumps and radio-frequency interference. At this price?! How cool is that?!
With over six decades of experience designing and building rock-solid products, Crown sets the standard in amplifier technology. So check out the affordable Crown XLI Series. They are a powerful argument for quality and value!
Specifications: • Power output, stereo mode (EIA 1 kHz, both channels driven): 1,000 watts x 2 (8 ohms), 1,350 watts x 2 (4 ohms) • Output power, bridged mono mode (EIA 1 kHz): 2,700 watts x 1 (8 ohms) • Distortion (typical): <0.5% @ 8 and 4 ohms • Frequency response (@ 1 watt, 20 Hz - 20 kHz): +0 dB, -1 dB • S/N ratio: >100 dB (A-weighted) • Crosstalk: @ 1 kHz >75 dB; @ 20 kHz >59 dB • Input sensitivity: selectable 1.4V or 0.775V • Input impedance: 20k ohms balanced, 10k ohms unbalanced • Load impedance: Stereo 4 ohms minimum per channel; 8 ohms minimum in bridge mono • Damping factor (8 ohms, 10 Hz - 400 Hz): >200 • AC power requirement: 120 VAC, 60 Hz • Dimensions: 3.5" (2RU) H x 19" W x 14.4" D • Weight: 43 lbs.
