  • Cooling Fan 12 VDC 80 x 80 x 25mm 39 CFM
Parts ExpressPart # 250-060
12 VDC cooling fan 80 x 80 x 25 mm.
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
  • Low noise
Your Price: $3.49
MSRP: $4.99
Save $1.50 (30%)
Quantity:Qty: 1-9 $3.49/ea
Quantity:Qty: 10+ $3.14/ea
We'll send you an email when Cooling Fan 12 VDC 80 x 80 x 25mm 39 CFM is back in stock or available for preorder.
Order in the next 1 hr 47 min to ship today. Details
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. These economical cooling fans are a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. These fans come with 3-pin header plug that can be removed for custom applications.
Specifications: • Operating voltage: 12 VDC • Power: 2 watts • Speed: 3000 RPM • Airflow: 39 CFM • Noise: 36 dB • Dimensions(W x H x D): 80 x 80 x 25 mm.
Part Number250-060
UPC848864007366
Weight0.154
Bearing TypeSleeve Bearing
Operating Voltage12 VDCV
Size80
