  • Ciare CT250 1" Neodymium Dome Tweeter Pair
Ciare
Part #293-100
Ciare
Part #293-100
Model: CT250
The Ciare CT250 1" Neodymium Dome Tweeter Pair is a set of high-quality tweeters designed to deliver exceptional high-frequency response and clarity.
  • Small size for easy installation almost anywhere
  • Extended frequency response in a small package
  • High strength neodymium magnets for unmatched efficiency
Your Price: $159.55
MSRP: $212.73
Save $53.18 (25%)
1In Stock
The Ciare CT250 1" Neodymium Dome Tweeter Pair is a set of high-quality tweeters designed to deliver exceptional high-frequency response and clarity. Featuring a neodymium magnet and a 1-inch diaphragm, these tweeters provide an impressive frequency response of 2kHz-20kHz, ensuring clear and accurate sound reproduction across the entire high-frequency spectrum.
The CT250's solid build quality and advanced construction ensure that these tweeters can handle high volumes without distortion, making them perfect for use in a wide range of applications. The neodymium magnet provides excellent efficiency, while the dome diaphragm ensures a smooth and natural sound.
The CT250's sleek and modern design makes them the perfect choice for any car or professional sound system. They also come with a range of mounting options, including flush, surface, and angle mounts, making them easy to install in any location.
Whether you're a DIY audio enthusiast or a professional sound engineer, the Ciare CT250 1" Neodymium Dome Tweeter Pair is the perfect choice for any audio project that demands exceptional high-frequency response and clarity.
BrandCiare
ModelCT250
Part Number293-100
UPC848864072982
Unit of MeasurePairs
Weight0.65
Cutout Diameter1.89
Tweeter TypeMetal Dome
Power Handling (RMS)75 Watts
Sensitivity91dB 2.83V/1m
Resonant Frequency (Fs)1400Hz
DC Resistance (Re)3.3Ω
Voice Coil Inductance (Le)0.08mH
Mechanical Q (Qms)0.97
Electromagnetic Q (Qes)1.23
Total Q (Qts)0.54
Overall Outside Diameter2.13"
Depth0.69"
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
