  • Behringer NU6000DSP iNUKE 6000W Lightweight Power Amplifier with DSP
CLEARANCE Behringer NU6000DSP iNUKE 6000W Lightweight Power Amplifier with DSP
Behringer
Part #248-6710
Behringer
Part #248-6710
Model: NU6000DSP
The NU6000DSP is part of the iNUKE Series amplifiers by Behringer with DSP control that delivers up to 6,000 watts 4 ohm, stereo.
  • Delivers 2 x 3,000 watts into 4 ohms, 2 x 1,500 watts into 8 ohms, and weighs less than 12 lbs.
  • Ultimate reliability through revolutionary cool-running High-Density Class-D technology with "near-zero" thermal buildup
  • Ultra-efficient switch-mode power supply for noise-free audio, superior transient response, and low power consumption
  • High-performance DSP and 24-bit/96 kHz converters deliver ultimate signal integrity and extreme dynamic range
  • DSP section features sophisticated delay, crossover (3 filter types, up to 48 dB/octave), EQ (8 parametric, 2 dynamic), dynamics processing, and lockable security settings
  • Front panel LCD display enables setup and adjustment without PC
iNUKE Series power amplifiers pack massive amounts of output power into exceptionally lightweight, rack-mountable packages. Behringer's revolutionary high-density Class-D technology combined with ultra-efficient switch-mode power supplies ensure these feather-light powerhouses will drive your rig effortlessly for many years to come. By carefully selecting transistors with extremely high slew rates and optimizing other proprietary parts of Behringer's circuitry, these amps react instantly to even the most demanding electronic bass impulses.
When this amazing amplifier technology is combined with our state-of-the-art switching-mode power supplies, these amplifiers provide tremendous punch. And because they are so much more efficient than conventional designs, they run cooler and don't require the massive heat sinks and heavy toroid transformers typically associated with their conventional counterparts.
The front panel controls and indicators provide your system's vital signs at a glance. After pressing the Power button, the Power LED lights to show the amp is ready for action. All channels feature positive-detent Gain controls with Signal LEDs that light when a signal is present, as well as clip LEDs to indicate when the signal is distorted and you need to reduce the input signal.
The rear panel is just as elegant, with combo XLR and 1/4" TRS input connectors making the iNUKE compatible with virtually any source, balanced or unbalanced. Professional twist-lock speaker sockets are provided to ensure every drop of output power gets to your loudspeakers. The rear panel is also where you'll find the switches that enable iNUKE amps to work in either dual mono, stereo, or mono bridge mode. A built-in CROSSOVER switch enables the amp to operate in biamp mode, sending low frequency content to passive subwoofers, while the high frequency output is channeled to full range loudspeakers (CH1>100 Hz / CH2<100 Hz or FULLRANGE).
For sound engineers requiring high-level control capability, iNUKE DSP Series amplifiers come ready for action right out-of-the-box. The built-in DSP and 24-bit/96 kHz converters ensure the ultimate signal integrity, with an extremely broad dynamic range. DSP functions include a sophisticated delay for delay-line loudspeakers, crossover, EQ (eight parametric, two dynamic), and dynamics processing with lockable security settings. A convenient front panel LCD display allows you to setup and make adjustments directly at the amplifier, without the need for a PC. All iNUKE DSP models can also be set up, controlled and monitored via the front panel USB connector.
Sporting massive output ratings, lightweight Class-D technology, an equally lightweight price tag, and all the amenities a professional audio engineer could ask for, Behringer iNUKE amplifiers are serious amps for the most demanding applications.
Specifications: • Output power (per channel, stereo): 1,100 watts RMS, 1,500 watts peak (8 ohms), 2,200 watts RMS, 3,000 watts peak (4 ohms) • Frequency response: 20 - 20,000 Hz, +0/-2 dB • Distortion: < 0.2% • Damping factor: > 140 @ 8 ohms • Signal-to-noise ratio: > 98 dB • Power supply: 120V, 60 Hz • Dimensions: 3.5" H x 19" W x 12.91" D (89 x 483 x 328 mm) • Weight: 11.9 lbs. (5.4 kg).
BrandBehringer
ModelNU6000DSP
Part Number248-6710
UPC705105166681
Weight15.5
Output Channels2
Weight Range10 to 19 lbs.
    MONSTER DEAL
    OF THE WEEK
    $98.98 EACH
    SAVE 40%
    Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
