Behringer DJX750 Pro 5-Channel DJ MixerNeed an analog DJ mixer for your dance club? Don’t want to settle for some run-of-the-mill DJ desk you'll outgrow in just a few weeks? The new PRO MIXER DJX750 DJ Mixer merges intuitive operation with built-in digital effects processing for clean, transparent sound that will set your dance floor on fire!
DJs the world over love the DJX700 — and we are grateful that so many have made it their "go-to" mixer. So when we began design on the DJX750, we knew we had to do something very special. We started by revving up the FX processor and putting advanced parameter control right at your fingertips. No longer are you confined to rigid presets that limit your creativity. With the DJX750, you can change FX parameters on-the-fly, pushing your performance to the next level. In no time you'll be creating powerful sets with your own custom-tailored effects sounds, all of which can be controlled in real-time. Some parameters at your disposal include Bit Crusher depth, manual filter sweeps, Panning (LFO Rate), delay/echo time and much more. You can even set delay and echo timing relative to the internal BPM counter for extremely musical results. It is kinda like a DJX700 — but one on steroids!
Channels Galore
Because your voice is your instrument, the DJX750 features a dedicated mic channel with all the tools to make your sound supremely distinctive. Vocal fine-tuning is handled by the onboard 3-band EQ, which provides up to 15 dB of boost or cut at LOW (80 Hz), MID (2.5 k), and HIGH (12 kHz) frequency centers — creating an extremely broad tonal palette. The DJX750's stereo channels' EQ utilize the same frequency centers with a boost of up to 12 dB and a cut of as much as -32 dB. These channels are equipped to handle every conceivable input source — from line level, phono, CD and tape decks to mp3 and minidisk players, we've got you covered.
Auto Ducking
DJX750’s talkover function automatically detects your voice and brings down the volume of the music track (referred to as "ducking"), so your voice is always out front — you can even set this level to your own personal preference. Auto BPM Counter Sync'ing up tracks is an art unto itself — that’s why we gave the DJX750 dual Auto BPM Counters. This cool feature helps take the guess work out of making a smooth transition from one track to the next. Each BPM counter’s digital display shows which channel it is tracking and the tempo of the music in beats per minute. Optionally, you can push the Beat Assist button in time with the song to manually enter the tempo. You get a read out of the tempo diff erence between the tracks, as well as a visual confirmation when they are in sync. These tools will help you seamlessly align two tracks — without having to rely solely on your ears.
Crossfader & Channel Faders
All of our super-smooth faders are of the high-grade 45-mm ULTRAGLIDE variety. Faders are, after all, the heart and soul of every mixer, and with their 500,000 cycle life expectancy (that's 275 fades per night, per fader for five years without a break!), they outperform standard faders more than twenty-to-one. And since the crossfader uses VCA (Voltage Controlled Amplifier) technology, there is virtually no audio noise. For those of you who prefer customized crossfading, the DJX750 also includes our CF Curve control, which lets you set the crossfader’s control characteristic just the way you like it. It is, after all, your show!
XPQ 3D
Making music larger than life is what it’s all about and the DJX750 comes through on this in a big way. XPQ 3D Surround widens the stereo field, giving it immense depth and a stereo image that is full of life, with amazingly transparent sound. You determine the intensity of this stunning effect with a simple twist of the Surround control — from barely noticeable to supremely spectacular.
Onboard Digital Effects
Really good digital effects add the finishing touch to a solid performance, and ours are really good! With 33 outstanding effects to choose from, including an assortment of Phase Shifters, Flangers, Reverbs, Delays and more, your audience won’t know what hit them. There are even Auto Filter and Voice Changer effects that will take your show to a whole new level.
Monitor Multi-tasking
You can’t put on much of a show if you can’t hear what you’re mixing! That’s why we didn’t cut any corners on DJX750’s monitor section. When the monitor Mode switch is in the "Split" position, you hear the PFL (Pre-Fader Level) output on the left side of your phones, and the Master signal on your right. If you prefer working in "Stereo" mode, you can turn the MIX control fully counterclockwise to hear the channel PFL signal in both sides of your headphones, fully clockwise for the Master output, or you can "mix" both signals by adjusting the control to anywhere in-between. You can listen to one or multiple sources, and LEDs light up to indicate what you’re listening to.
Sound Quality
None of the above-mentioned features would amount to much if the DJX750 didn't sound truly remarkable. That's why we equip each one with our tried-and-true ULN (Ultra Low-Noise) preamps: what comes in comes out, with nothing added. So you get maximum headroom, extremely low noise and ultra-transparent sound. Compare it to the competition for sound quality, features and value and you’ll see why more and more DJs "own the night" with their Behringer DJX750.
