  • BOSS R63 Riot 6-1/2" 3-Way 300W Full-Range Speaker Pair
$24.95
Free Shipping available on orders over in the US. Details
The performance of the Riot Series provides powerful, high quality audio. The custom designed poly injected cones and regimented linear travel provide an accuracy of sound production transporting the exact sonic experience the artist intended in the recording studio, directly into your vehicle.
Poly Injection Cone
Polyurethane is a resilient, flexible and a durable manufactured material that allows for maximum flexibility that produces great sounding speakers lasting you a long time.
High Temperature Voice Coil
Boss speakers are capable of higher or elevated temperature strength and fatigue properties that will increase performance and efficiency of heavy duty play time through lower weight and higher operating temperatures.
Resilient Rubber Surround
Impermeable to air, rubber has the ability to endure or resist exposure to the many types of weather fronts. The surround connects the cone to the basket.
Generally, the Mylar dome tweeter is a step up from the semi-dome tweeter, primarily because of improved sound dispersion. The dome shape radiates sound with a wider dispersion pattern than the semi-dome design. Since high-frequency sound waves are directional, a wider dispersion of the sound waves will give you more flexibility to work with when setting up your system.
Type: 6-1/2" 3-way full range
Woofer: 6-1/2" Polyurethane
Mid-range: 1"
Tweeter: 1/2" Mylar dome
Power handling: 300 watts PEAK (per pair), 150 watts PEAK (each)
Frequency response: 100-18,000 Hz
Sensitivity: 92 dB
Impedance: 4 ohms
Voice coil: 1" Aluminum
Basket structure: Cast
Mounting depth: 2.18"
Mounting diameter: 5.1"
