BOSS NX694 Onyx 6"x9" 4-Way Full-Range Speaker Pair 800WThe classic style performance of the ONYX (NX) Series are a rare combination indeed. The custom designed poly injected cones and regimented linear travel provide an accuracy of sound production transporting the exact sonic experience the artist intended in the recording studio, directly into your vehicle.
Poly Injection Cone
Polyurethane is a resilient, flexible and a durable manufactured material that allows for maximum flexibility that produces great sounding speakers lasting you a long time.
High Temperature Voice Coil
Boss speakers are capable of higher or elevated temperature strength and fatigue properties that will increase performance and efficiency of heavy duty play time through lower weight and higher operating temperatures.
Resilient Rubber Surround
Impermeable to air, rubber has the ability to endure or resist exposure to the many types of weather fronts. The surround connects the cone to the basket.
Generally, the dome tweeter is a step up from the semi-dome tweeter, primarily because of improved sound dispersion. The dome shape radiates sound with a wider dispersion pattern than the semi-dome design. Since high-frequency sound waves are directional, a wider dispersion of the sound waves will give you more flexibility to work with when setting up your system.
Type: 6" x 9" 4-way, full range
Tweeter: 1" Mylar dome
Power handling: 800 watts RMS (per pair), 400 watts RMS (each)
Frequency response: 45-20,000 Hz
Sensitivity: 92 dB
Impedance: 4 ohms
Voice coil: 1.5"
Basket structure: Stamped
Mounting depth: 3.27"
Mounting hole: 5.82"
Dimensions: 7" x 9" x 4"
