  • BIC Formula F-12 12" 475 Watt Subwoofer
CLEARANCE BIC Formula F-12 12" 475 Watt Subwoofer
BIC AmericaPart # 303-436
Model: Formula F-12
The F-12 Subwoofer surpasses its competitors in performance, range, and sound quality by handling both low-frequency sounds and musical tones with exceptional fidelity.
  • Patented BIC "Venturi" vent eliminates port noise
  • 12" injection-molded cone woofer with heavy duty surround
  • 475 watts peak amplifier designed by Bash Technology
  • High level and LFE (Low Frequency Effects) inputs
  • Five year maufacturer's warranty on parts and labor
Dayton Audio SUB-1200 12" Powered Subwoofer
Price: $199.98Part # 300-629
See all items in Powered Subwoofers
We'll send you an email when BIC Formula F-12 12" 475 Watt Subwoofer is back in stock or available for preorder.
The BIC Formula F-12 powered subwoofer incorporates a high current 475 watt peak amplifier featuring BASH technology in combination with a 12" injection molded long-throw woofer. A patented BIC "Venturi" vent eliminates port noise that is often heard from other subwoofers, especially when playing demanding music and videos. The F-12 also features an adjustable crossover, adjustable volume control, automatic signal sensing, high level inputs, and LFE (Low Frequency Effects) inputs. Finish: black laminate.
The Formula F-12's list of attributes makes it an ideal choice for home theater enthusiasts and audiophiles alike. The F-12’s frequency response range, crossover range, peak power output, and overall volume output combine to make it one of the best performing subwoofers available in its price range. 5 year parts and labor warranty.
Specifications: • Power handling: 150 watts RMS/475 watts peak • Impedance: 8 ohms • Frequency response: 25 - 200 Hz • SPL: 90 dB • Dimensions: 17" H x 15" W x 17-1/2" D • Weight: 42 lbs. • Sold individually.
BrandBIC America
ModelFormula F-12
Part Number303-436
UPC729305003638
Weight44.25
Woofer Diameter12"
