  • B&C ME90 1.4" Constant Directivity Horn 80x60 4-Bolt
3 Questions, 6 Answers or
B&C Speakers
Part #294-626
B&C Speakers
Part #294-626
Model: ME90
The B&C Speakers ME90 1.4" constant directivity cast aluminum horn is designed to accommodate the latest generation of 1.4" exit high-performance compression drivers.
  • 80°H x 60°V nominal dispersion
  • Durable cast aluminum construction
  • Constant directivity coverage pattern
Your Price: $91.13
MSRP: $151.88
Save $60.75 (40%)
Estimated back in stock 3/28/2025
Alert Me When Available
B&C's ME90 1.4" constant directivity cast aluminum horn features smooth, medium-dispersion 80° x 60° coverage, and its high reliability is a result of all-metal construction. The ME90 is rotatable when installed (may be turned sideways to suit varying applications) and provides very good driver loading down to 900 Hz.
Specifications: • Nominal dispersion: 80°H x 60°V • Minimum frequency: 900 Hz • Throat diameter: 1.4" • Dimensions: 10.6"H x 10.6"W x 5.5"D • Cutout dimensions: 8.8"H x 8.8"W • Mounting type: Standard 4 bolt.
B&C Speakers produces a series of horns for compression drivers ranging from constant directivity models, known for their great consistency in angular coverage, to exponential models, which optimize acoustical loading and sound energy transfer. Standardized driver mounting flanges give the designer the freedom to choose the best horn/driver combination for each project.
All horns are made of cast aluminum, resulting in a robust structure that is free from resonances. The only exception to this method is the ME10; a new design that is made from precision molded plastic and incorporates stiffeners that add to its structural integrity. B&C combines advanced design techniques with critical listening tests to manufacture horns that exhibit precise pattern control, excellent driver loading, and low distortion and coloration.
BrandB&C Speakers
ModelME90
Part Number294-626
UPC844632001901
Weight4.2
ConstructionAluminum
Entry / Throat Diameter1.4"
Mounting Type4-Bolt
