Audio-Technica ATW-1102 System 10 Digital Wireless Microphone SystemAudio-Technica's System 10 handheld wireless microphone system provides your rig with great flexibility. The sleek, stylish, stackable design of the receiver also features balanced XLR and unbalanced 1/4" outputs so that the system can be used with a variety of audio products. Easy-setup and operation of the unit allows you to spend less time hassling with the product and more time rocking your gig.
In addition to ease of use, the ATW-1002a provides you with a clear, natural sound quality and with reliable performance and durability. The receiver's advanced dipole antenna system means that the system has an extended range of operation so you don't have to stress about the microphone dropping signal. The system uses the 2.4 GHz ISM band (2400 to 2483.5 MHz).
Specifications for the system: • Operating frequencies: 2.4 GHz ISM band (2400 to 2483.5 MHz) • Modulation mode: FM • Dynamic range: >=90 dB (A-weighted), typical • Total harmonic distortion: <0.05% typical • Operating range: 100 ft. (60 m) • Frequency response: 20 to 20,000 Hz.
Specifications for the ATW-R1100a receiver: • Receiving system: Non-diversity, single-channel, dual antenna system • XLR audio output: balanced, 350 mV • 1/4" audio output: unbalanced, 700 mV • Power supply: 100~240 VAC to 12 VDC • Dimensions 7.48" W x 1.82" H x 5.06" D.
Specifications for the transmitter: • RF power output: 10 mW • Batteries: Two 1.5V AA (not included) • Dimensions: 9.91" long, 2.11" diameter.
