  • Audio-Technica ATH-SPORT7TW SonicSport Wireless In-Ear Headphones
CLEARANCE Audio-Technica ATH-SPORT7TW SonicSport Wireless In-Ear Headphones
Audio-TechnicaPart # 240-5583
Model: ATH-SPORT7TWBK
The Audio-Technica SPORT7TW SonicSport true-wireless in-ear headphones provide great sound with extreme comfort and stability making them ideal for jogging, walking, and working out. Bluetooth connections with mic and touch controls give you convenient control over playback, volume adjustments, and taking calls. The IPX5 waterproof rating ensures the headphones will hold up to water and sweat for the ultimate protection from moisture damage. Long headphone and case battery life provides uninterrupted playback, the quick charge functions delivers 45 minutes of playback on a 10 minute charge.
  • In-ear sport headphones with ergonomic Freebit ear fins for maximum stability and comfort
  • Ideal for active use (jogging, working out, etc.)
  • Bluetooth wireless technology with mic and touch-sensor control built into the earpiece for convenient handling of calls, music playback and volume adjustment and supports the Audio-Technica Connect app for convenient control of headphone settings
  • Lab tested and certified IPX5 waterproof rating allows headphones to be washed after use and includes standard eartips (XS, S, M, L), Comply foam eartips (M) with SweatGuard technology, ear fins (XS, S, M, L), and 30 cm USB charging cable
  • 5.8 mm drivers deliver powerful sound
  • Switchable hear-through function enables ambient noise to be heard through headphones for safer use outdoors
  • Internal battery provides 3.5 hours of continuous use on a full charge with portable charging case allows you to charge the headphones 4 times (17.5 hours total) without connecting to an AC power source
We'll send you an email when Audio-Technica ATH-SPORT7TW SonicSport Wireless In-Ear Headphones is back in stock or available for preorder.
The ATH-SPORT7TW true wireless in-ear headphones will help keep you motivated and moving during your workouts - with absolutely no wires to get in your way! The headphones come with four interchangeable sizes (XS, S, M, L) of ergonomic Freebit ear fins to give you a custom - and comfortable - fit designed to stay in place during physical activity. The headphones also have a certified IPX5 waterproof rating, so you can wash the sweat off them and have them ready for your next workout.
The ATH-SPORT7TW in-ear headphones are equipped with powerful 5.8 mm drivers to deliver outstanding sound reproduction. There’s a mic and touch sensor built into the earpiece, allowing you to answer calls, control music playback, and adjust the volume on your smartphone or other device. You can also access the Audio-Technica Connect app on their smartphone to quickly and easily adjust headphone settings. For additional safety when using outdoors, particularly in areas with heavy traffic, the headphones include a switchable hear-through function that lets you to hear ambient noise.
The headphones provide 3.5 hours of continuous use on a full charge, and can be recharged up to 4 times using the included portable power bank charging case for a total of 17.5 hours of use. The charging case even features a quick charge function, which gives you 45 minutes of playback from a 10-minute charge.
In addition to the ear fins, the headphones come with four sizes of interchangeable eartips (XS, S, M, L), one pair of Comply foam eartips (M) with SweatGuard technology, and a 30 cm (1.0') USB charging cable for the charging case.
IEC rating IPX5 (Washable). The headphone may be washed using running water (not completely waterproof).
Type: Dynamic
Driver diameter: 5.8 mm
Frequency response: 20-25,000 Hz
Sensitivity: 91 dB/mW
Impedance: 14 ohms
Line of sight connection range: 10 m (33 ft.)
Bluetooth: Bluetooth v 5.0
Compatible Bluetooth profiles: A2DP, AVRCP, HFP, HSP
Support codec: AAC, SBC
Battery: Headphones - DC 3.7V lithium-ion battery, battery case - lithium polymer battery
Battery life: (depending on operating conditions) Max. approx. 3.5 hours
Charging time: Headphones appox. 2 hours (depending on operating conditions), charging case approx. 3 hours (depending on operating conditions)
Accessories included: USB charging cable (30 cm USB Type A / Micro USB Type B), Eartips (XS, S, M, L), Ear fins (XS, S, M, L), Comply foam eartips (M)
Type (microphone): MEMS
Sensitivity (microphone): -42 dB (1 V/Pa, at 1 kHz)
Frequency response (microphone): 100-8,000 Hz
Polar pattern (microphone): Omnidirectional
Weight: Approx. headphones (left & right combined): 12.8 g (0.4 oz), charging case: approx. 64 g (2.2 oz)
BrandAudio-Technica
ModelATH-SPORT7TWBK
Part Number240-5583
Weight0.56
ColorBlack
Fit StyleIn-Ear / Earbud
Type or Typical UseHi-Fi / Portables
Special FeaturesBluetooth / Wireless-Device Control-Microphone-Sport / Water Resistant-Storage Bag Case-Volume Control
