  • Audio-Technica AT-VM95E Turntable Phono Dual Magnet Cartridge 1/2" Mount 0.3 x 0.7 mil
Audio-Technica
Part #240-5644
Audio-Technica
Part #240-5644
Model: AT-VM95E
This 1/2" mount AT-VM95E phonograph cartridge offers outstanding clarity and detail. Reviewers have rated this affordable, high-performance cartridge as a best buy value.
  • Utilizes standard half-inch mounting
  • Specially wound coils increase output voltage
  • Aluminum cantilever
  • Threaded inserts in cartridge body enable cartridge to be mounted to headshell with just two screws – no nuts required
  • Durable low-resonance polymer housing
  • Compatible with any AT-VMN95 replacement stylus
Your Price: $69.00
Order in the next 19 hr 5 min to ship today. Details
This VM95 Series cartridge with 0.3 x 0.7 mil elliptical stylus fits half-inch mount turntables. The cartridge's special coil design delivers a powerful output level of 4.0 mV. It also offers excellent channel separation and low distortion for outstanding tonal quality. The durable, low-resonance housing includes threaded inserts that enable the cartridge to be mounted to the headshell with just two screws — no nuts required. And since all VM95 Series share the same body, the stylus can be replaced with any of the six interchangeable AT-VMN95 replacement styli. Manufactured to Audio-Technica's renowned quality standards, each cartridge is meticulously assembled with remarkably tight tolerances.
Specifications:• Frequency response: 20-20,000 Hz • Channel separation: >20 dB at 1 kHz • Tracking force range: 1.8-2.2 g (2.0 g standard) • Recommended load impedance: 47,000 ohms • Output: 4.0 mV (1 kHz, 5 cm/sec) • Channel balance: 2.0 dB • Stylus type: 0.3 x 0.7 mil elliptical diamond stylus • Cantilever: Aluminum pipe • Mount: Half-inch • Accessories included: Two 11 mm installation screws, two 8 mm installation screws, two washers.
BrandAudio-Technica
ModelAT-VM95E
Part Number240-5644
UPC4961310146016
