Audio-Technica AT-SB727-YL Sound Burger Compact Portable Turntable YellowCrafted for portability, the Sound Burger seamlessly blends a retro aesthetic with modern enhancements. Perfect for gatherings, compact living spaces, or outdoor picnics, this budget-friendly entry-level turntable boasts Bluetooth® connectivity, USB charging, and a playback duration of up to 12 hours.
The Sound Burger ensures top-notch sound reproduction through its belt-drive system, catering to both 33-1/3 and 45 RPM records. For a harmonious balance between portability and stability, the tonearm utilizes a dynamic balance system that applies stylus pressure through a spring mechanism. Additionally, a high-precision DC motor maintains a consistent rotation.
With its Bluetooth connectivity and compact, lightweight design, the Sound Burger is an ideal companion for parties, picnics, or snug living spaces. Easily connect to your Bluetooth headphones or speakers, and relish your favorite vinyl records wirelessly for a duration of up to 12 hours.
This unique turntable showcases a die-cast aluminum alloy platter with a damping design and a replaceable ATN3600L stylus (available separately). For those who prefer a wired, analog listening experience, the Sound Burger includes an audio cable.
Included Accessories: 45 RPM adapter, 3.5 mm male to dual RCA male audio cable, USB Type-A/USB Type-C™ charging cable.
- DC Servo Motor
- DC 3.6V lithium ion battery
- Belt-drive
- 33-⅓ and 45 RPM speeds
- Aluminum platter
- SNR: >50dB
- Wow and flutter: <0.25% (WTD) at 3kHz
- Cartridge type: VM
- Output level: 150 mV nominal at 1 kHz, 5 cm/sec (No phono-output)
- Phono preamp gain: 36 dB nominal, RIAA equalized
- Charging Specifications: 5V, 0.5A
- Power consumption (when charging): 1.5W
- Charging time: Approx. 12 hours
- Operation time: Approx. 12 hours
- Input: USB Type-C
- Dimensions: 100 mm (3.9") × 290 mm (11") × 70 mm (2.8") (W×D×H)
- Weight: Approx. 900 g (32 oz)
- Operating temperature: 5°C to 40°C (41°F to 104°F)
- Included accessories: ・USB cable (1.5 m (5'), USB Type-A - USB Type-C) ・RCA audio cable ・45 RPM adapter
- Bluetooth version 5.2
- Maximum Bluetooth range: Approx. 33' (10m) line of sight
