  • DAC Digital to Analog Converter with Toslink Passthrough (5.1 Compatible)
CLEARANCE DAC Digital to Analog Converter with Toslink Passthrough (5.1 Compatible)
Part #180-1141
Part #180-1141
This digital to analog audio switch converter allows you to simultaneously convert any one of four digital input sources (2 x Toslink, 2 x coax) to multiple analog outputs including stereo RCA, Toslink, and 3.5 mm for use with headphones. High-fidelity sample rate support of up to 192 kHz / 24-bit provides you with audiophile quality sound.
  • Four digital audio inputs (2 x Toslink, 2 x coax) to analog audio converter with SPDIF/Toslink, stereo RCA, and 3.5 mm outputs
  • High-fidelity sample rates of up to 192 kHz / 24-bit for superb audio quality
  • Supports LPCM, DTS, Dolby-AC3, THX, and HDCD audio formats
  • Features an auto input sensor, over-voltage protection, and input status indicator
  • Compatible with 5.1 format
Supporting a wide array of popular audio formats such as LPCM, DTS, Dolby-AC3, THX, and HDCD, this converter is a perfect fit when needing to switch and convert multiple digital audio sources to a single analog output. The DAC is compatible with 5.1 format. Connect devices such as PCs, DVD players, gaming systems, or other digital inputs to the unit's array of input sources while connecting the analog outputs to your audio system to convert digital audio to analog. Select input source via the built-in switch. The unit also features automatic input sensing, last working state memory, over-voltage protection, and input status identification.
Audio inputs: 2 x Toslink, 2 x Coax
Audio outputs: Stereo RCA, 3.5 mm, Toslink
Supported audio formats: PCM/LPCM
Digital input level: 0.1 - 1V p-p
DAC sample rate: 32-192 kHz
RCA output level: 1V RMS (1 kHz @ 0 dB)
Headphone output level: 30 mW (1 kHz @ 0 dB RL=32)
SNR: 90 dB (@ 0 dB CCIR/ARM)
Distortion: 0.1%
Frequency response: 20-20,000 Hz
Power supply: 5 VDC (AC adapter included)
Certifications: FCC, CE, RoHS
Dimensions: 3.3" x 2.5" x 1.0"
Part Number180-1141
UPC848864061627
Weight0.65
