  • Atlas Sound SM82T-B 8" 2-Way Speaker Black 70V
Atlas Sound
Part #242-826
Atlas Sound
Part #242-826
Model: SM82T-B
The Atlas Sound Strategy Series® II two-way, surface-mount loudspeaker systems are ideal for indoor and outdoor installation in conference rooms & classrooms, boutiques/shops, restaurants/cafes, decks/patios, recreation/sport centers, amusement/theme parks, and houses of worship.
  • Weather resistant construction for year-round indoor or outdoor use
  • UV-resistant, talc impregnated, polypropylene injection molded enclosure
  • Powder coated aluminum grill
  • Conforms to stringent 100HR salt spray test per the ASTM B117 standard
  • Color matched heavy-duty C-shaped mounting bracket is included
  • TRX WaveGuide™ high frequency director for vocal and music accuracy and clarity
  • SAE 1/4"-20 brass inserts allow easy integration of "off-the-shelf" security hardware
Your Price: $361.99
MSRP: $450.99
Save $89.00 (20%)
The Atlas Sound Strategy Series® II two-way, surface-mount loudspeaker systems are ideal for indoor and outdoor installation in conference rooms & classrooms, boutiques/shops, restaurants/cafes, decks/patios, recreation/sport centers, amusement/theme parks, and houses of worship. For surface mount applications where increased output and tighter pattern control in an environment-resistant, contemporarily styled enclosure is required, the SM82 series is the perfect choice. System components consist of a highly efficient 8" HYCONE™ treated woofer and 1" exit titanium compression driver. Sold individually.
Specifications: • Power rating: 60 watts (xfmr. limited) • 70.7V Taps: 1.9, 3.8, 7.5, 15, 30, 60 watts • Frequency response: 65 Hz-20 kHz • Sensitivity: 92 dB 1W/1m • Dispersion 65°H x 65°V • Dimensions (less bracket): 16-1/2" H x 9-1/16" W x 8-7/16" D • Mfg. #SM82T-B.
BrandAtlas Sound
ModelSM82T-B
Part Number242-826
UPC612079178889
Weight22
ColorBlack
Configuration2-way
Input Rating8 ohm|70V|100V
Woofer Diameter8"
Special FeaturesIndoor / Outdoor-Water Resistant
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
