  • Atlas Sound PD-5VH 40W Compression Driver
Atlas Sound
Part #242-858
Atlas Sound
Part #242-858
Model: PD-5VH
Featuring an Alnico V-DG magnet, the Atlas Sound PD-5VH 40W compression driver provides an extended frequency response for optimum intelligibility. The powerful driver for large format horns delivers a powerful, rich sound to music, public address, and signaling systems. The 2" voice coil is machined to the optimum tolerances. The driver also provides terminals direct to the 16 ohm voice coil.
  • Powerful driver for large format horns to deliver powerful sound reproduction
  • Extended frequency response to create the optimum intelligibility
  • Great for indoor and outdoor use with environment resistant construction
  • Ideal for music, public address, and signaling systems
  • Popular Leslie replacement for Jensen V-21
Your Price: $188.99
MSRP: $233.99
Save $45.00 (19%)
The 40W, 16 ohm Atlas Sound PD-5VH compression driver provides a powerful, intelligible, extended frequency response to large format horns. The 2" voice coil is machined to the optimum tolerances. Equipped with an Alnico V-DG magnet, the PD-5VH offers maximum temperature stability and optimizes output for yielding the lowest amplifier power requirements. The driver also provides terminals direct to the voice coil. The units are finished in gray, baked epoxy and mounts to large format horns that terminate in standard 1-3/8"-18 male coupling thread.
Specifications: • Power rating: 40W @ 16 ohms • Plane wave frequency response: 110 - 4,100 Hz • Sensitivity: 110.7 • Impedance: 16 ohms • Voice coil: 2" • Dimensions: 5.125" H x 4.375" W.
BrandAtlas Sound
ModelPD-5VH
Part Number242-858
UPC612079117130
Weight3.9
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
