  • Arlington Industries TVBU505K 2-Gang Recessed Power and Low Voltage TV Box Kit
1 Question, 1 Answer or
Part #261-4250
Model: TVBU505K
Get everything you need to install your home theater system cables and connectors into an existing wall with the Arlington TVBU505K recessed power and low voltage box kit.
  • Quick and easy installation
  • Mounting wings hold boxes securely against wall
  • Paintable finish
  • For walls up to 1-1/2” thick
Your Price: $38.99
MSRP: $51.99
Save $13.00 (25%)
Quantity:Qty: 1-3 $38.99/ea
Quantity:Qty: 4+$37.04/ea
2In Stock
The Arlington TVBU505K TV box includes a recessed power and low voltage combo and all the connections you need to install a flat screen TV cables in an existing wall. Featuring power in one side and low voltage in the other for Class 2, the TVBU505K is perfect for wiring satellite or cable TV, speakers and more. This TV box mounts securely in walls up to 1-1/2" thick and can be installed in new constructions of retrofit into existing home theaters. UL and CSA listed. Made in the USA.
BrandArlington Industries
ModelTVBU505K
Part Number261-4250
UPC018997096821
Weight1
