We use cookies to provide the best possible customer experience across this site, through third party ads and analysis of web data. By continuing you agree to our use of cookies and our overall privacy policy.
The American Audio 14 MXR is a great MIDILOG™ mixer with midi/analog control. It has a built-in DSP D-Core sound card with 4-in/4-out audio interface, balanced XLR outputs, and MIDI navigation controls and user assignable control buttons which make it easy to customize and play your music.
We'll send you an email when American Audio 14 MXR 14" 4-Channel DJ Mixer and MIDI Controller w/Virtual DJ LE is back in stock or available for preorder.
The 14 MXR is is a great mixer/controller in the American Audio lineup. Jam-packed with powerful features and capabilities, but still easy to use and affordable, the 14 MXR is an excellent choice for DJs at all levels of experience.
The 14 MXR puts 4 channels of MIDILOG™ input under your complete control, which accommodate not only the USB interface with your computer, but also analog inputs such as microphones, CD players, turntables, and more. You get two combination XLR - 1/4" microphone inputs, as well as four stereo line inputs, two of which may be used with turntables (including ground screws). The internal DSP D-Core soundcard is a 4-in/4-out audio interface with 20 on-board buttons and controls which can be mapped to virtually any "MIDI Learn" capable software. However, the included Virtual DJ LE software is already custom mapped to the 14 MXR, so it's ready to go right out of the box. Load the software on your computer, plug in the 14 MXR, and you're up and running quick and easy.
Some of the additional features of the 14 MXR include 3-band EQ with rotary kills, included Feather Fader Plus (innoFader compatible), and crossfader channel assign, curve adjustment, as well as Master, Booth, Headphone Level and Mix controls.
Whether you're an up-and-coming or seasoned veteran DJ, the 14 MXR gives you what you need to provide an exciting and professional performance every time, right at your fingertips.
Specifications: • Frequency response: 10 - 20,000 Hz • THD: ≤ 0.1% • Cross talk: -55 dB • Dimensions: 14.25" x 13.75" x 3.5" (356 x 320 x 85 mm) • Weight: 10 lbs. (4.5 kg).
Brand
American Audio
Model
14MXR
Part Number
244-4498
UPC
819730017277
Unit of Measure
Each
Weight
10
Mic Inputs
2
Stereo Line Input Channels
4
Special Features
USB Connectivity
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
