  • Large Adjustable Drywall and Ceiling Tile Hole Saw Cutter for Ceiling Speakers Lights 1.5" to 11" With Dust Shield
Parts ExpressPart # 360-300
The cutting tool is adjustable from 1.2" to 11.8", allowing you to easily and quickly cut round speaker holes in drywall and ceiling tiles without the mess.
  • Cuts circles up to 11.8" diameter
  • Carbide tipped blades for longevity of life
  • Two blades counter balance the cutter for low vibration
  • Dust shroud keeps debris from obscuring your work area
  • Includes extra set of blades
Your Price: $69.98
MSRP: $109.99
Save $40.01 (36%)
We'll send you an email when Large Adjustable Drywall and Ceiling Tile Hole Saw Cutter for Ceiling Speakers Lights 1.5" to 11" With Dust Shield is back in stock or available for preorder.
Expected back in stock any day
If you install speakers or can lights, this circle hole cutter is a must have! The cutting tool is adjustable from 1.2" to 11.8", enabling you to tackle the biggest jobs without making a mess. Carbide tipped blades and high-speed steel bits will go through drywall and ceiling tiles with ease. A ball-bearing collar in the dust shroud allows the cutting tool to spin effortlessly. The complete kit includes the circle cutting tool, one set of carbide tipped and one set of high-speed steel cutting blades, one carbide tipped and one high speed steel arbor bit, dust shroud, five wood and five masonry drill bits, tape measure and pencil, all organized in a heavy duty case. Maximum cut depth is 1-1/4", overall plastic shield diameter is 14-1/4". Not recommended for use on concrete or hardwoods.
Part Number360-300
UPC844632085949
Weight7.75
