  • 6V 500mA DC Switching Power Supply AC Adapter with 2.1 x 5.5mm Center Positive (+) Plug
$6.98
Free Shipping available on orders over in the US. Details
Replace or Add This AC Adapter to Your Next 6 VDC Project
This 6 VDC AC adapter has a 6 ft. cord with a 2.1 x 5.5 mm tip positive plug, which offers a decent reach for you to connect your device comfortably. It is also UL approved, ensuring that it has been tested for safety and meets industry standards. This plus other certifications give you peace of mind knowing that the adapter has gone through rigorous testing.
The output voltage of this adapter is 6 VDC, which is suitable for devices that require a 6-volt power supply. The current capacity is 500 mA, meaning it can deliver up to 500 milliamperes of current to your device. It is important to match the voltage and current requirements of your device to ensure proper functionality. Look for the symbol below on your device which may have a lower mA, but can't be higher.
Overall, this AC adapter provides a versatile and reliable power source for your electronic device. Its wide input voltage range, UL approval, and appropriate output voltage and current capacity make it a suitable choice. So go ahead and power up your device with confidence!
Specifications: • Output voltage: 6 VDC @ 500mA • Input voltage: 100-240 VAC @ 50/60 Hz • DC output cord length: 6 ft. with 2.1 mm x 5.5 mm x 9 mm with center positive plug • Dimensions without the AC prongs: 1.4" D x 1.55" W x 2.42" H.
