  • 3M 03584 Professional Grade Rubberized Sound Damping / Undercoat Spray Net Wt. 1 lb. (454g)
3M
Part #340-350
3M
Part #340-350
For a quieter ride, 3M 3584 rubberized undercoating helps insulate the vehicle cabin from noise, including from the road and the engine. When soundproofing an automobile, consider the most common source of the noise for your situation.
  • Multi-purpose undercoating may be applied to cars, truck and recreational vehicles
  • Sound deadening properties help reduce road noise
  • Aerosol dispenser allows for easy spray-on application in cracks and seams where sound deadening sheets can't reach
  • Asphalt-based product is excellent for wheel wells, quarter panels, interior fenders, under the hood and more
Your Price: $10.98
MSRP: $15.99
Save $5.01 (31%)
Quantity:Qty: 1-5 $10.98/ea
Quantity:Qty: 6+$9.98/ea
Professional Grade Rubberized Undercoating helps protect the undercarriage of cars, trucks, vans and recreational vehicles from corrosion and abrasion. The coating may also be used to protect wheel wells, quarter panels, interior sides of fenders, the underside of the hood, the bottom sides of floor pans and more. Protecting your vehicle with an application of rubberized undercoating is advised for long-term protection of the undercarriage. Rubberized undercoating creates a protective barrier that seals out grit, grime and moisture that could otherwise corrode the metal components. The spray goes on as a textured black finish that resists chipping, abrasion, exterior rusting and weathering. It provides one-coat build-up with no dripping, running, or sagging. This extra protection is a low-cost measure that can pay off by potentially extending the service life of a vehicle.
The rubberized undercoating also helps deaden noise, allowing for a more pleasant and quieter ride. Road and engine noise interrupt music created by todays quality car stereos. Adding sound proofing sheets to doors, hoods, and trunks are the best way to seal out unwanted sounds. Unfortunately these sheets are unable to reach corners which prevent the perfect seal from outside sounds. 3M's 3584 professional grade undercoat spray is the perfect solution to finish the job. It also helps deaden unwanted sounds inside metal or plastic speaker cabinets.
Note: After finishing final coat, let the undercoat air dry for several hours before touching. Use in a well ventilated area.
Brand3M
Model03584
Part Number340-350
UPC051131035843
Weight1.35
