  • 3.5mm Mono Plug to 3.5mm Stereo Jack Audio Headphone Adapter
BUYOUT 3.5mm Mono Plug to 3.5mm Stereo Jack Audio Headphone Adapter
Factory Buyouts
Part #099-067
Factory Buyouts
Part #099-067
The high quality gold plated 2-conductor 3.5 mm male, plugs into a mono jack and the 3.5 mm 3-conductor jack turns the signal into two mono channels for stereo headphones, and amplified speakers. It also combines a stereo 3.5 mm plug into a 3.5 mm mono plug for mono
  • Gold plated for maximum signal transfer
  • Common 3.5 mm size plug and jack
  • Turns a single channel into two channels
If you've ever plugged a stereo headphone or amplified speaker into a mono jack, you noticed that sound only came out to one side. Add this adapter plug and you'll hear sound out of both sides. Add this adapter to a male 3.5 mm stereo to two RCA male Y-cable and send a mono signal to the left and right channel of a stereo amplifier or mixer.
This adapter plug also combines a 3.5 mm male stereo source into one channel for a PA amplifier with a 3.5 mm mono input. The adapter's maximum size is 1.62" L x 0.51" W (41 x 12.9 mm). The width tapers down to 0.4" (10.3 mm)
BrandFactory Buyouts
Part Number099-067
UPC848864051161
Weight0.01
