  • 16WBD88A 6-1/2" Paper Cone Speaker 8 Ohm
BUYOUT 16WBD88A 6-1/2" Paper Cone Speaker 8 Ohm
Factory Buyouts
Part #299-4336
Factory Buyouts
Part #299-4336
Model: 16WBD88A
The 16WBD88A 6-1/2" Paper Cone Speaker utilizes a lightweight paper cone, cloth surround and stylish chrome dustcap. A 7/8" single-layer voice coil wound on a paper former combine to make a very low 6.12 gram moving mass for above average efficiency.
  • High 91 dB efficiency
  • 2.1mm Xmax for increased low-end
  • Great choice for use in multiples for low powered amplifiers
BUYOUT $5.98
Quantity:Qty: 1-9 $5.98/ea
Quantity:Qty: 10-19 $5.48/ea
Quantity:Qty: 20+$4.98/ea
333In Stock
The 16WBD88A 6-1/2" Paper Cone Speaker utilizes a lightweight paper cone, cloth surround and stylish chrome dustcap. A 7/8" single-layer voice coil wound on a paper former combine to make a very light 6.12 gram moving mass for above average efficiency of over 91 dB. With an 8 ohm impedance, these can easily be used in pairs for an inexpensive, high efficiency speaker system.
BrandFactory Buyouts
Model16WBD88A
Part Number299-4336
UPC848864074115
Weight1.5
Nominal Diameter6-1/2"
Bolt Circle Diameter6.125
Power Handling (RMS)20 Watts
Power Handling (MAX)40 Watts
Frequency Response75 to 6,000Hz
Sensitivity91.24dB 2.83V/1m
Voice Coil Diameter0.875"
Resonant Frequency (Fs)75.13Hz
DC Resistance (Re)7.177Ω
Voice Coil Inductance (Le)0.4661mH
Mechanical Q (Qms)4.071
Electromagnetic Q (Qes)0.8929
Total Q (Qts)0.7323
Compliance Equivalent Volume (Vas)0.6399ft³
Diaphragm Mass Inc. Airload (Mms)6.128g
Maximum Linear Excursion (Xmax)2.1mm
Surface Area of Cone (Sd)130cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerPaper
Overall Outside Diameter6.625"
Baffle Cutout Diameter5.75"
Depth3.25"
Sealed Volume0.7ft³
Sealed F397.2Hz
Vented Volume0.8ft³
Vented F367Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
