  • 12 VDC Bluetooth 4.0 FM Radio MP3 WAV FLAC Audio Preamp Board with Function Cables and Remote
Part #320-348
Part #320-348
This preamp module adds Bluetooth 4.0, media player, and FM to an audio amp, or powered speaker DIY project. Its 12 VDC input voltage makes it perfect for car audio upgrades.
  • 9 - 12 VDC working voltage for flexibility
  • LED display identifies play mode and Bluetooth connection for convenience
  • Includes IR remote for wireless control
  • Auto-shutoff when no signal is detected saves power
  • Preset equalizer settings enable sound customization
  • Includes power, audio output, and FM antenna cable for quick installation
  • Plays APE FLAC WAV WMA MP3 audio files
Your Price: $21.49
MSRP: $26.99
Save $5.50 (20%)
Quantity:Qty: 1-9 $21.49/ea
Quantity:Qty: 10+$19.34/ea
Why only add Bluetooth to an audio DIY project when FM radio, media player, Aux in, and Bluetooth are all available in one preamp module with LED display? Hook up the audio output using the included cable to an amp board. The preamp includes a two-conductor cable that hooks up to a 9-12 VDC source and a wire that plugs in to the FM antenna socket. Cutout a 2.1" x 4" rectangle hole and mount the Bluetooth module into your project, and you now have an FM radio, media player, and Bluetooth available with faceplate controls. You must use the included remote to change FM stations by punching in the station's frequency.
Play APE FLAC WAV WMA MP3 audio files through this Bluetooth 4.0 preamp module with a USB/SD flash memory card and adjust the sound with preset EQ levels built into the module. Adjust the sound wirelessly with a Bluetooth EQ app on a smartphone, or use the included IR remote to control volume, EQ, play, FM station selection, and source functions. Add these options to an older car stereo that only has an Aux input for an external source. The possibilities for this all-in-one faceplate preamp Bluetooth module are only limited by your imagination.
Note: USB jack is not a charging port.
Specifications: • Outer dimensions: 4.7" W x 2.5" H x 1.14" D • Cutout dimensions: 4" W x 2.1" H • Input voltage: 9 - 12 VDC • Included cables: One 8" 3-conductor Aux output, one 8.5" FM antenna, and one 2-conductor 9" power.
Part Number320-348
UPC848864033099
Weight0.25
Board TypePreamp
Special FeaturesBluetooth-FM Tuner-Remote Control-SD Card Input-USB Connectivity
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
