  • 12-10 AWG Red/Black DC-H Hi-Amp Quick Disconnects 50A 2 Pair
Part #263-201
Part #263-201
Create individual DC quick disconnects or lock the connectors together to form a multi-conductor quick disconnect.
  • Outer plastic housings lock together for multi-conductor applications
  • Durable Red and black plastic housings for easy polarity identification
  • Includes crimp connect terminals for quick installation
Your Price: $9.79
MSRP: $16.99
Save $7.20 (42%)
Quantity:Qty: 1-3 $9.79/ea
Quantity:Qty: 4+$8.81/ea
Order in the next 9 hr 46 min to ship today. Details
8In Stock
Make quick disconnect single, or multiple conductor connections with these durable red and black locking connectors with terminals. Crimp the metal terminals to your individual wires and then insert them into the plastic housing until the lock in place. Match the corresponding color for the right polarity and hook the two plastic housings together. The two metal terminals are kept tightly together by an internal metal flat spring. There is no male or female connection to worry about. Firmly pull the two housings apart to disconnect.
These quick disconnects work as multi-conductor connectors also. The plastic housings slide together and are kept in place by included metal pins. This enables you to create a two conductor connector or buy another set to make a three or four conductor connection.
Specifications: • Wire gauge accepted: 12-10 • Current rating: 30A • 2 red and 2 black plastic housing dimensions: 1.9" L x 0.67" H x 0.67" D at its largest points • 4 metal terminal dimensions: 1.2" L x 0.25" W x 0.09" D • 2 metal pins: 0.20" Dia. x 0.61" L.
Part Number263-201
UPC848864053110
Unit of MeasurePackages
Weight0.1
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
