  • Z5325 3" Replacement Speaker 3 Watt 8 Ohm
BUYOUT Z5325 3" Replacement Speaker 3 Watt 8 Ohm
Factory Buyouts
Part #299-4316
Factory Buyouts
Part #299-4316
Model: Z5325
The Z5325 3" Replacement Speaker utilizes a ribbed paper cone and paper surround for lightweight effiency. A neodymium motor and flat, easy to install frame make this a great budget option as a replacement, or for a custom build.
  • Lightweight paper cone for added efficiency
  • Neodymium magnet for reduced weight
  • Simple flat frame for easy mounting
BUYOUT $0.88
Quantity:Qty: 1-9 $0.88/ea
Quantity:Qty: 10-19 $0.78/ea
Quantity:Qty: 20+$0.68/ea
368In Stock
BrandFactory Buyouts
ModelZ5325
Part Number299-4316
UPC656403841339
Weight0.15
Nominal Diameter3-1/2"
Bolt Circle Diameter3.9375
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response200 to 9,000Hz
Sensitivity83.36dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)203.8Hz
DC Resistance (Re)7.824Ω
Mechanical Q (Qms)15.32
Electromagnetic Q (Qes)8.978
Total Q (Qts)5.661
Compliance Equivalent Volume (Vas)0.0524ft³
Diaphragm Mass Inc. Airload (Mms)0.9557g
Surface Area of Cone (Sd)40.72cm²
Cone MaterialPaper
Surround MaterialPaper
Voice Coil FormerPaper
Magnet MaterialNeodymium
Overall Outside Diameter3.5"
Baffle Cutout Diameter3.375"
Depth1.25"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
