  • Yamaha S115V 15" 2-Way Professional PA Speaker
CLEARANCE Yamaha S115V 15" 2-Way Professional PA Speaker
Yamaha
Part #247-6091
Yamaha
Part #247-6091
Model: S115V
The Yamaha S115V 15" PA speaker carries on the long-standing tradition of excellence for which the Concert Club series of speakers is known. The new Mark V series is a complete redesign of some of the most popular speakers ever produced, but never loses sight of what's always made them great.
  • Powerful 15" woofer and 2" VC horn driver for unmatched sound quality
  • 700 watts peak power handling
  • Flawless performance with EMX powered mixers or P Series power amps
  • Parallel 1/4" and speakON connectors
  • Durable carpeted wood cabinet
The original Concert Club series of loudspeakers by Yamaha set the standard for performance, sound quality, durability and reliability. Each revision of the line has built upon this solid foundation, and the Mark V series is no exception. Painstaking selection of parts and components, optimized wood enclosures, and a thorough reevaluation of speaker capacity have given the new Concert Club V series a robust sonic presence that takes their performance to a new level. Even as your system changes and expands years down the road, you can expect the Concert Club series to deliver consistently excellent audio quality.
Thoughtful Design for Longevity
A classic, unpretentious design makes these speakers virtually timeless. The slightly rounded front grill enhances both style and durability. The Concert Club V series features a durable exterior with a carpeted surface, and large metal handles for improved portability. They're designed to endure the rigors of a sound reinforcement system that will be set up and taken down night after night. And, all front-of-house and monitor models are equipped with a pole socket for use with speaker stands. You can place these speakers on a standard 1-3/8" diameter speaker stand or subwoofer pole for a variety of applications.
Powerful Protection
As a much-requested solution to the problem of tweeter destruction that is a regrettably common occurrence in the equipment and studio rental business, the Concert Club series is provided with a protection circuit that prevents excessive tweeter input due to acoustic feedback or other causes.
Specifications: • Frequency response (-10 dB): 55 - 16,000 Hz • Power rating: 500 watts continuous; 1000 watts peak • Impedance: 8 ohms • Sensitivity (1w/1m, on-axis): 99 dB • Maximum SPL (calculated): 129 dB • Dimensions: 19-1/4" x 28-1/4" x 14-7/8" (489 x 719 x 377 mm) • Weight: 64.8 lbs. (29.4 kg).
BrandYamaha
ModelS115V
Part Number247-6091
UPC086792728148
Weight69.9
ConfigurationFull-Range PA Speaker
Speaker TypePassive / Unpowered
Woofer Size15"
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
