Access and play all of your music with a simple and easy to control app that allows you to wirelessly stream it throughout your home using your existing Wi-Fi network.
Listen to Pandora, Spotify, Napster, SiriusXM Internet Radio, TIDAL, Deezer, thousands of free internet radio stations and the music stored on your smart devices and computers.
All MusicCast products are fully loaded with Wi-Fi, Bluetooth and AirPlay.
When you’re ready, add MusicCast wireless speakers, sound bars or other devices in up to 9 other rooms and listen throughout your home.
By using MusicCast, you don't need to fuss with placing wires through walls into other rooms.
Ultimate Wireless Control
The free MusicCast controller app puts control of your wireless A/V system in the palm of your hand. Use the MusicCast Controller app to operate the system and change settings, select your sources and control music playback.
Stream Wirelessly via Bluetooth or AirPlay
You can listen to any music source you desire from your smartphone via wireless a Bluetooth connection. Equipped with the latest Bluetooth technology, making wireless operation more convenient than ever. Stream music from the receiver to Bluetooth headphones, for private listening, or to a Bluetooth speaker for a get together. You can play music from music apps, radio apps, or YouTube™-type video hosting services.
This AV receiver supports AirPlay, which means it can accept wireless music streaming from an iPod touch®, iPhone®, or iPad®, as well as from iTunes® on a Mac® or PC. This makes it easy to enjoy music from your mobile devices or computer on your home theater system. You can view metadata such as song title and artist's name as well as album art via the on-screen display of the AV receiver.
No Break for Your Music
Many live and classical albums have no gaps in the music. Gapless playback ensures that there are no pauses between audio files. This provides playback with no wasted time, the way it was meant to be heard. Compatible with WAV, FLAC, AIFF, and ALAC file formats, it also works with input from USB / DLNA / DMP.
• File formats: MP3, WMA, MPEG4 AAC, WAV, FLAC, AIFF, ALAC, DSD
• Minimum RMS output power: 100W x 2 (8 ohms, 40 Hz-20 kHz, 0.2% THD)
• Maximum output power: 140W x 2 (8 ohms, 1 kHz, 10% THD
• Frequency response: 0 ± 0.5 dB / 0 ± 3.0 dB
• Signal-to-noise ratio (CD): 100 dB (Input shorted, 500 mV)
• Audio in/out: 6/1
• Ethernet: Yes
• Headphone out: Yes
• Dimensions (W x H x D): 17-1/8" x 5-1/2" x 13-3/8" (with antenna up: 17-1/8" x 7-7/8" x 13-3/8")
