Yamaha AG06MK2 B 6-Channel Mixer/USB Interface for iOS/Mac/PC BlackThe AG06MK2 boasts a range of tactile controls, including a spacious 60mm fader, enabling intuitive and swift audio adjustments. Its newly incorporated mute button allows instant mic input cessation when the situation requires it. Moreover, the reverb and mute functions can be managed effortlessly using the optional FC5 foot switch, liberating your hands for other essential tasks.
Apart from accommodating a condenser microphone of your preference, the AG06MK2 is equipped with a 1/4-inch jack input for connecting guitars or line instruments. It also boasts an enhanced 4-pole mini jack (TRRS) enabling seamless smartphone input and output functionalities.
Additionally, the AG06MK2 offers the LOOPBACK function, allowing you to playback audio signals from a connected USB device to USB streaming output, a feature reminiscent of the previous AG series mixers.
By utilizing USB-C connectivity and implementing advanced internal circuitry, the AG06MK2 achieves a significant enhancement in sound quality. This improvement elevates your streaming audio to a more professional standard, ensuring a superior listening experience.
Regardless of your specific streaming needs, adding depth and dimension to your audio is crucial for a professional touch. The AG06MK2 is equipped with optimized 1-TOUCH COMP/EQ and REVERB controls, allowing you to customize the sound to match your style. Additionally, it features a 1-TOUCH amp simulator that adds authenticity and punch to your guitar input.
All of these features are processed through the internal DSP chip, ensuring there's no delay. This real-time accuracy is particularly valuable for live streaming scenarios where timing is essential. Moreover, if you prefer to capture unaltered, raw recordings using your preferred microphone and edit them later, you have the option to completely disable these effects.
The AG Controller software provides users with effortless and precise control over the DSP audio processing within the AG system. With its "Simple" and "Detail" modes, AG Controller offers a tailored experience for users of diverse music production backgrounds. Whether you're on Windows, Mac, or iOS, this software allows detailed audio management from any connected device, enhancing the capabilities of the AG06MK2 via USB.
The AG06MK2 boasts a sleek, slim, and compact design, allowing it to be conveniently placed on almost any flat surface. Alternatively, when paired with the optional BMS-10A adapter, it can be effortlessly mounted on a microphone stand. Additionally, it can be linked to a mobile battery, creating a minimalist and mobile streaming station that can be set up anywhere.
Please note that for the stable operation of the AG06MK2, a power supply of DC 5V 900mA or higher is necessary.
Product Information
• 60 mm faders for mic CH1
• +48 V phantom power on CH1 input for condenser mics or Dl boxes
• Hi-Z input for guitars on CH2
• High resolution (24-bit, 192 kHz) 2-track audio recording and playback
• 4-pole mini input/output (TRRS) to support a wider range of streaming applications
• Flexible inputs and LOOPBACK function ideal for live streaming or recording
• Mute button for convenient live streaming
• Easy control and pro sound with Amp Simulator and 1-TOUCH COMP/EQ, REVERB
• AG Controller (Windows/Mac/iOS) for precise parameter control
• Windows/Mac support by USB-C connection
• iOS connectivity via Apple Camera Adapter (requires external USB power supply)
• Android supported by 4-pole mini input/output (TRRS)
• USB-C power input (5 V DC, 900 mA)
• Cubase Al, WaveLab Cast, Cubasis LE and Rec'n'Share are available
