  • Wattgate 320 evo Black IEC AC Power Connector
Wattgate
Part #110-488
Wattgate
Part #110-488
Model: 320 EVO GLOSSY BLACK
Wattgate's 320 evo IEC Power Connector is the answer for those seeking the perfect power performance. The 320 evo combines solid construction with heavy duty brass contacts.
  • Accepts 8 to 14 AWG wire
  • Use cable with a diameter up to 19 mm
  • WattLock terminals for heavy duty wire capture
  • Polycarbonate design with all non-magnetic materials
  • High spring rate brass contacts
  • 2.5 mm hex socket hardware holds individual wires tightly
Your Price: $39.79
MSRP: $59.99
Save $20.20 (34%)
Quantity:Qty: 1-3 $39.79/ea
Quantity:Qty: 4-24 $37.98/ea
Quantity:Qty: 25+$33.47/ea
Order in the next 3 hr 58 min to ship today. Details
7In Stock
The WattLock terminals lock in wire gauges from 8 to 14 so you can be confident that heat or vibrations will not dislodge your connections. This connector accepts cable diameters up to 19 mm. The Cryo treatment Wattgate employs means you get maximum AC transfer for premium sonic benefits to both audio and video equipment.
Construction of the connector body is all polycarbonate and uses all non-magnetic materials to reduce interference. These plugs are rated 125 VAC, 15 amp. Housing dimensions: 2.2" L x 1.5" D. Overall dimensions: 2.97" L x 1.5" D.
BrandWattgate
Model320 EVO GLOSSY BLACK
Part Number110-488
UPC601431104888
Weight0.25
ConfigurationIEC
Current Rating15A
Power Connector TypeCable Mount
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
