  • Visaton K50FLS-8 2" Waterproof Miniature Driver with Mylar Diaphragm 8 Ohm
Visaton
Part #292-726
Visaton
Part #292-726
Model: K50FLS-8
The Visaton K50FLS-8 is a 2" miniature speaker with a plastic (Mylar) diaphragm. Its compact design and good speech reproduction make it suitable for applications where space is limited and in outdoor environments.
  • Rated power of 1W and maximum power of 2W
  • Frequency response from 350–20000 Hz
  • IP65 protective system when built into a sealed enclosure
  • Can withstand temperatures ranging from -40 °C to +70 °C
  • Compact design ideal for signal output in machines and equipment with limited space
Your Price: $5.98
MSRP: $6.73
Save $0.75 (11%)
Quantity:Qty: 1-9 $5.98/ea
Quantity:Qty: 10+$5.50/ea
Order in the next 10 hr 7 min to ship today. Details
24In Stock
The Visaton K50FLS-8 is a 2" miniature speaker designed to deliver clear sound reproduction, particularly for speech, in environments where space is a constraint. The speaker features a Mylar diaphragm, which contributes to its compactness and durability. With its compact design, the K50FLS-8 is ideal for signal output in machines and other equipment where installation space is at a premium. Despite its small size, this speaker offers a broad frequency response range from 350–20000 Hz, making it a versatile option for various audio requirements. The K50FLS-8 has a rated power of 1W and a maximum power of 2W. It demonstrates impressive performance across a wide temperature range, from -40 °C to +70 °C, making it well-suited to outdoor applications and environments with generally unfavorable conditions. When built into a sealed enclosure, this speaker has an IP65 protective system, providing a good level of protection against dust and water.
BrandVisaton
ModelK50FLS-8
Part Number292-726
Nominal Diameter2"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response350 to 20,000Hz
Sensitivity85dB 2.83V/1m
Voice Coil Diameter0.51"
Resonant Frequency (Fs)570Hz
Overall Outside Diameter1.97"
Baffle Cutout Diameter1.81"
Depth0.31"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
