  • Visaton K34WP-8 1-1/2" Miniature Waterproof Driver 8 Ohm
Visaton
Part #292-728
Visaton
Part #292-728
Model: K34WP-8
The Visaton K34WP-8 is a 1.3" miniature speaker featuring a plastic basket and diaphragm. With its balanced frequency response and voice reproduction, it's particularly suited for outdoor applications and environments with high humidity.
  • Rated power of 1W and maximum power of 2W
  • Balanced frequency response range of 320–20000 Hz
  • Can withstand temperatures ranging from -40 °C to +70 °C
  • IP64 protective system when built into a sealed enclosure
Your Price: $5.48
MSRP: $5.73
Save $0.25 (4%)
Quantity:Qty: 1-9 $5.48/ea
Quantity:Qty: 10+$5.04/ea
Order in the next 9 hr 52 min to ship today. Details
36In Stock
The Visaton K34WP-8 is a 1.3" miniature speaker designed for applications that require consistent audio performance in potentially challenging conditions. It features a plastic basket and diaphragm, and is particularly well suited to outdoor applications and situations with high humidity levels. The speaker offers a balanced frequency response range from 320–20000 Hz, providing good voice reproduction. With a rated power of 1W and a maximum power of 2W, it's an optimal choice for monitoring speaker requirements in electronic devices and outdoor systems. The K34WP-8 is designed to withstand a wide temperature range, from -40 °C to +70 °C. When built into a sealed enclosure, it has an IP64 protective system, ensuring a degree of protection against dust and water splashes. Connections are made via solder joints, providing a secure and reliable connection. The Visaton K34WP-8 offers a dependable audio solution for various applications, particularly in outdoor and high humidity environments.
BrandVisaton
ModelK34WP-8
Part Number292-728
Weight0.01
Nominal Diameter1-1/2"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response320 to 20,000Hz
Sensitivity79dB 2.83V/1m
Resonant Frequency (Fs)570Hz
Overall Outside Diameter1.33"
Baffle Cutout Diameter1.29"
Depth0.2"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
