  • Terk FM50 Indoor/Outdoor Amplified FM Antenna
CLEARANCE Terk FM50 Indoor/Outdoor Amplified FM Antenna
Terk
Part #210-220
Terk
Part #210-220
Model: FM50
The TERK FM Pro is a high performance indoor/outdoor antenna engineered for superb FM reception over long distances. The FM Pro can be installed under the eaves of a roof, on an inside or outside wall or as a roof-top antenna.
  • Slim-profile design
  • Wide variety of indoor and outdoor mounting options
  • Weatherproof housing
  • Paintable
The TERK FM Pro is a high performance indoor/outdoor antenna engineered for superb FM reception over long distances. The FM Pro’s patented half-wavelength folded dipole design and built-in Dual Mode ultra-low-noise amplifier provides clear and powerful reception of both distant and close FM stations. Acclaimed by reviewers for its standard-setting performance, the FM Pro is the ultimate antenna for the FM radio enthusiast. The FM Pro can be installed under the eaves of a roof, on an inside or outside wall or as a roof-top antenna. Its durable, weatherproof housing is paintable to blend with any home decor. Included Accessories: (1) Power Injector (to operate Dual-Drive amplifier), (1) 75 ohm-to-300 ohm adapter, (1) 75 ohm to 75 ohm twin-lead adapter.
Specifications: • Reception Pattern: Figure 8 • Frequency Range: 88 to 108MHz • Amplifier Gain: Switchable 0dB/+11dB • FM Impedance: 75 ohm (300 ohm with supplied adapter) • Terminals: Gold-plated 75-ohm “F” connector • Power Supply: 12V DC 100ma UL listed • Voltage Regulator: Internal • Dimensions: 57” W x 2-1/2” H x 1-1/4” D.
BrandTerk
ModelFM50
Part Number210-220
UPC034405500001
Weight6
    MONSTER DEAL
    OF THE WEEK
    $14.98 EACH
    SAVE 25%
    Dayton Audio Boost Mini Portable Bluetooth Speaker Black
